Originally Posted by pbarge
Hey thanks for the ideas! I'll check out the voltage monitor...we don't usually boondock, but it is a possibility in the future....I'll check the charging status tomorrow while plugged in shore power....
Remember, if checking battery "charge status" using just a voltmeter that can mean two different things.
One would be the voltage the battery has reached while being charged. When low it will draw lots of current from the charger (converter) and voltage will be low. As charge increases it will rise. During this process all the voltmeter will tell you is that the battery is charging.
Second, if you want to know the actual State of Charge you will need to shut down the charger and let batteries sit for several hours (overnight is good) THEN read the voltage. While charging batteries take on what's known as a surface charge. This is much higher than the resting voltage that indicates the true State of Charge.
If you need to determine the true state of charge and have just shut off the charger (converter), turn on some 12 volt items. All the lights and fans for example, and let them run for 10 minutes. Turn off. This will help reduce the surface charge and give a somewhat accurate reading but the "overnight method" is best. If not "overnight" just wait several hours. Longer the better.
Now print out one of the Lead Acid State of Charge/Voltage charts posted online and post it next to your voltmeter. Should be fine for your needs if you aren't a boondocker.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
