My inverter has a simple transfer switch built into the inverter. It will power the outlets via ac when plugged in. When the ac shore power is not available and the inverter switch is on, the inverter will power the outlets. I would look at the inverter fuses and make sure that the are all ok.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
