Old 05-14-2021, 10:27 PM   #1
Have Camera will Travel
Canadian Eh's Avatar
DC to DC converter
I am in the process of switching over to Lithium batteries. I have the charge controller and need to add a DC to DC converter to the alternator. Considering the size of the E450 I was surprised at how little firewall or fender space there is to mount one.
I see one extra #4 wire going into the battery box but I'm not clear on how the charging system works. How can I tell which lead is coming off the alternator to charge the house batteries.
2018 Sunseeker 2430S-CD
Ex Canadream Rental
Canadian Eh is offline   Reply With Quote
Old 05-15-2021, 01:07 PM   #2
When you install a DC-DC charger you don't want to connect to the alternator but rather to the Pos and Neg terminals of the Starting Battery.
The DC-DC charger will draw it's power directly from the starting battery and the alternator will provide current to both battery and charger.
Depending on the manufacturer of the DC-DC charger their install manual will show proper connection as well as fuse locations and sizes for both wires from the Starting battery and to the house batteries.
The DC-DC charger does not need to be mounted under the hood and can be mounted near the house batteries (mine is mounted inside my TT right next to my Battleborn batteries) as long as the wire from starting battery to DC-DC charger is large enough (again, it's in the manual).
Don't worry about fan noise if you mount the DC-DC charger in or close to living space. Fan only runs while driving (or engine running).
By connecting directly to the battery (Negative cable, not using chassis ground) any current sensor used to monitor charge of starting battery will still function properly and house batteries won't be starved of charging current once starting battery is full. Connecting both Pos and Neg to the battery lets the current sensor and house batteries as one and will keep current flowing until both are fully charged.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-15-2021, 04:33 PM   #3
Thanks.
Ex Canadream Rental
Old 05-17-2021, 01:06 PM   #4
You "need" to add the DC2DC or you "want" to add?
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
jbflag21ds is offline   Reply With Quote
Old 05-17-2021, 04:42 PM   #5
I was under the impression that I required a DC to DC converter for the alternator current. That if I didn't have one in line that the draw on the alternator could burn it out.
Ex Canadream Rental
Old 05-17-2021, 05:01 PM   #6
You don't have a DC2DC already installed? How was your unit charging the existing batteries?
2021 Flagstaff 21DS
Old 05-17-2021, 05:15 PM   #7
PhilFromMaine's Avatar
Exactly! Lithium will suck up all the current you can give it and destroy your alternator. You must have a DC2DC charger to put restraints on the voracious thirst for current that lithium batteries have.
As Mike said, most people mount the DC2DC charger near the house batteries on the TT. I ran my 4 awg wires from my TV terminal battery fuse to the bed of my pickup on the side wall near the tailgate at an Anderson Terminal receptacle. From there I connect to another Anderson connector on the TT near the DC2DC charger as needed.
I just noticed you have a class C. Same idea, but a little easier than a TV-TT install.
PhilFromMaine is offline   Reply With Quote
Old 05-17-2021, 05:44 PM   #8
I have AGM batteries now and will be upgrading to Lithium in the future.
Ex Canadream Rental
Old 05-17-2021, 07:45 PM   #9
Your AGM's will benefit too. You can set dip switches for their desired charge profile.
2004 Nissan Titan
converter
