03-10-2017, 10:11 AM
Dead battery
We are new to this, just bought our used 16ft wolf pup. Tried it out for the first time with no power and the battery went dead. Came home plugged in, charged battery and everything seemed fine. Next day battery was dead again. Something seems to be draining battery when parked. Can't figure out the problem. Any help would be appreciated. Thanks! Dan
03-10-2017, 10:26 AM
Dead battery
Is it a deep cell battery or regular car battery? That may be something you could check. Since it was used it may have bad battery and won't keep a charge anymore. Check battery to see if there is a manufacture date.
You do have parasite draws on your battery. Radio if it has clock, fridge, co2 alarms. If you leave unplugged for a while you may want to instal battery disconnect or disconnect the battery when setting idle not plugged into shore power.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
03-10-2017, 10:27 AM
Fonzie
03-10-2017, 10:28 AM
Battery is toast. Replace it.
Yes, there is a lot of paracitic draw on newer RVs, but dead in 24 hours indicates to me battery is gone south without you.
03-10-2017, 10:32 AM
Check breakaway switch. If cable is pulled, it will kill battery quickly. Did the brakes work when you were towing? Also take battery to auto parts store, they can load test. If it was left parked with dead battery before you bought it, Battery may not be able to accept any reasonable charge. It will still show charged when on charger, but will drop quickly once disconnected. If you want to experiment at home. Charge battery, disconnect negative terminal from TT. Let it sit two days. Now measure battery with hydrometer or connect negative terminal and try lights. If battery is dead after sitting unconnected only option is to replace it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-10-2017, 01:13 PM
Dead battery
Thanks I will try this but when I charged this battery than connected it again there were sparks making me think there was a draw
03-10-2017, 04:31 PM
Left Coast
Got a 12 volt test light?.... Insert it between neg post and cable.....Light on?....Draw.....Start pulling fuses and see if a fused circuit is where your draw is....
03-10-2017, 05:00 PM
World Wide Wanderer
I will guarantee you there is a draw, probably more than one. On my Coleman 16FBS I had over 2 amps of parasitic draw.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
03-10-2017, 07:26 PM
If you have smoke or carbon detectors they could be drawing the juice. I would buy and install a battery cut off switch. Easy install and will solve your problem. Also if you battery has a bad cell that will cause it to go,dead.
03-10-2017, 07:52 PM
If you are really killing your battery overnight, you have more than a parasitic draw. Earlier this week another member had a similar situation and it was his breakaway switch.
You can also check.
Fridge.
tongue jack light.
Outside lights.
TST Tire Monitors
2 100W solar panels
03-10-2017, 08:14 PM
Charge the battery leave it unhooked over night and check to see if it went flat on its own
How old is the battery there will be a sticker with a letter and number on letters a to l for the month number for the year I f manufacturer
Cold weather and if it sat dead or weak wreaks havoc on batteries
