Delay/Relay solinoid problems
I'm new to this forum and hope I'm not covering old ground.
I experienced a ground problem between the 12v cable coming from the truck alternator and on the cable from the relay solenoid on the coach. This forum does allow enough text for me to describe how to find and fix the problem, but it was a bear.
Got nylon bushings w/collar that would allow the 1/4 " mounting bolts and a nylon washer for the other side of the metal box. Got the mounting hubs installed and insulated and everything works as he should.
This forum does allow enough text to walk through the process but a ground in the electric system can leave you looking at a burning coach. I got lucky, very lucky.
