Old 12-16-2015, 09:39 PM   #1
Who Dares, Wins
doc73's Avatar
DO you use your Progressive Monitor when using a generator?
SO the previous thread about using the PI in parallel got me a thinking (and I got not want to hijack yet another thread!)... I do not use my PI unit when I am using my geni, never really thought it was needed. AM I WRONG? I was not really worried about the power coming out but as my little (yes very little) gears were turning in my head, I wondered if by running out of gas, lets say, on the geni could it cause a low voltage issue and damage something. I am using two eu2000 Honda's in parallel here, sometimes just one. They seem to just stop making power when the idle gets too rough or they start to shut down, but never actually looked at what was going on with the power output.
Any ways, thoughts?
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-16-2015, 09:44 PM   #2
For onboard gensets Progressive recommends to protect the shore line only and wire in before the transfer switch. I am thinking the same would apply to a stand alone genset.
Karl4Cat is offline   Reply With Quote
Old 12-16-2015, 09:47 PM   #3
Who Dares, Wins
doc73's Avatar
So then I would surmise your answer is a no? Its stand alone and would be monitoring the power into the unit through the shore line but if I read your response correctly you are saying not to monitor any geni input.
2015 ChevyHD D-Max
Old 12-16-2015, 09:50 PM   #4
Yes, sorry if it wasn't clear. Progressive says there is no danger in genset output. Only shore power.
Old 12-16-2015, 09:54 PM   #5
On my Georgetown 337DS I hard wired the Progressive to the coach end of the shore line. When using the Onan, it feeds to an outlet and I plug the shore line to it. So the Progressive protects the Onan feed as well as campground feed. Why not have 100% protection?
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
mogman is offline   Reply With Quote
Old 12-16-2015, 09:59 PM   #6
Not sure of the reason. Perhaps because gensets don't cause an issue? But Progressive does recommend not protecting the genset feed.
Old 12-16-2015, 10:48 PM   #7
Kenny kustom's Avatar
It wouldn't be a low voltage.
More like. Stop voltage. Be the same as unplugging the cord.
If it ran out of fuel.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-16-2015, 11:01 PM   #8
HONDAMAN174's Avatar
Only problem I have with using the PI while on generator is when at altitude and power is reduced. Sometimes it will cut off power when running microwave so I just flip the switch and bypass until I am done making bacon.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 12-16-2015, 11:21 PM   #9
TURBS's Avatar
I've used my pi with gennie for 5 years with no issues.
Albeit a 7000 watt gennie not 2 unit paralleled .
Old 12-16-2015, 11:25 PM   #10
Phat Phrog Stunt Crew
elind's Avatar
I have a TRW Surge Protector hardwired in my FW and it is either feed by shore power or my genny. It runs fine on either power source.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 12-16-2015, 11:33 PM   #11
Left Coast
With 2 hondas, I run an extended stay tank set-up......In summer heat, start 1 at about 8am and the other about 10: 30....shut them off at 10 pm......will run this way for 3 days and have gas lelt over......marine type gas tank with my own lash up....runs thru pi with no problems using the 'special grounding plug'
Old 12-16-2015, 11:36 PM   #12
Who Dares, Wins
doc73's Avatar
I have the extended tank as well. Have not made up the plug. Might be a winter 3 second project! Thanks all for the responses.
2015 ChevyHD D-Max
Old 12-16-2015, 11:44 PM   #13
Left Coast
For the plug, i used a 30 amp plug so that the normal plug-ins would be free if needed.
Old 12-17-2015, 10:51 AM   #14
elind's Avatar
If you use the 20 amp plug the breaker will kick out at 20 amp. If you get an adapter for the 30 amp plug on your Honda 2000 companion it will allow you to use the full 26 amps without tripping the breaker.
2014 Wildcat 327ck
Old 12-17-2015, 10:56 AM   #15
Left Coast
I knew there was a reason I did that! I also made mine semi waterproof......post a pic later today
Old 12-17-2015, 05:12 PM   #16
Who Dares, Wins
doc73's Avatar
The generator or the plug?
2015 ChevyHD D-Max
Old 12-17-2015, 05:50 PM   #17
Left Coast
the plug.....go take a pic in a second Because This tread isn't show'n up on Tapatalk, unable to post pic...sorry
Old 12-17-2015, 06:03 PM   #18
Left Coast
ID:	96357Click image for larger version
Sent from my XT1080 using Tapatalk
Old 12-17-2015, 06:04 PM   #19
Left Coast
Oh I'm good!
Old 12-17-2015, 07:07 PM   #20
Who Dares, Wins
doc73's Avatar
That is a SERIOUS plug!!! LOL, Thanks!
2015 ChevyHD D-Max
generator
