Old 02-16-2017, 04:01 PM   #21
If you trace your battery's positive lead to your factory installed battery disconnect switch and see any other wires terminated on the same lug of that switch that the battery cable terminates to, there's your parasitic load. Same applies in reverse: if you trace that same positive lead back to the battery and see any other wires on that terminal going back into or under the trailer, there's a parasitic load the disconnect switch won't terminate.
For informational purposes, I removed a wire shared with the positive battery lead on the disconnect switch that went to a junction box underneath my unit, and now have a 100% disconnect of my battery bank when needed.
I suspect the factory wanted certain equipment to always be powered; liabilities perhaps.
metalsideup is offline   Reply With Quote
Old 02-16-2017, 04:03 PM   #22
I should add that the wire I removed from the battery's lug was connected on the other (electrical load) lug.
Old 02-17-2017, 10:27 AM   #23
I do have and use the battery disconnect switch. I also added a 400 watt solar charger to mine. My 3 batteries haven't drop below 14v all winter.
szabla is offline   Reply With Quote
Old 02-17-2017, 10:34 AM   #24
Factory Battery Disconnect
Originally Posted by Oakman View Post
The factory installed battery disconnect in my Silverback kills power to all the parasitic drains in the trailer including the propane detector.
X2 on my Shamrock. Only thing the switch doesn't kill is the electric hitch as that is connected directly to the battery.
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018, 38 in 2019, 37 in 2020
CNYCamper is offline   Reply With Quote
Old 02-17-2017, 10:47 AM   #25
Oakman's Avatar
Yes, on my Silverback the front landing gear and rear electric stabilizers are hard wired to the battery so the cutoff switch doesn't affect them. Those two components don't have a parasitic draw.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-17-2017, 12:52 PM   #26
Canadian Member
I installed a Blue Sea Systems 6006 ON-OFF switch on mine. I put it on the positive side.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
battery, switch
