Old 04-15-2024, 01:20 PM   #1
Dometic Fridge Light problem
So the light doesn't work on my fridge, so far I've:
Replaced the bulb, and tried yet a third bulb.
Checked the fuses in the outside accessible black box.
Unplugged the connection to the top spade on the switch.
Nothing is connected to the bottom spade of the switch.
I don't know if the switch is bad, the assembly is bad or if something is not connected. New to me motorhome so I don't know if it ever worked.
Dometic model DM2652RBX
How is the switch supposed to work? What goes to the bottom spade?
2011 Sunseeker 2650S
Elliot Mess is offline   Reply With Quote
Old 04-15-2024, 01:58 PM   #2
See the attached manual, the twentieth page (which is labelled "21"). The switch is item H. One wire goes directly to the lamp, item G. The other switch terminal has a red wire going to terminal J2 on the control board and a wire connecting to the heating cable.
File Type: pdf Dometic-DM2652-Operating-Instructions-compressed.pdf (4.89 MB, 19 views)
Larry
Larry-NC is offline   Reply With Quote
Old 04-15-2024, 03:10 PM   #3
So there's a piece of metal that sticks out of the side of the fridge that the bottom spade on the switch should be touching. When I put a screwdriver in between the two the light went on. I could not bend that piece enough to make it keep contact, so I put a couple of pieces of plastic behind it (between it and the bulb terminal) this shim pushed the spade and that metal tab together and has fixed the problem.
No idea what happened and why this problem existed, but it seems OK now.
Old 04-15-2024, 03:21 PM   #4
Good to hear that you found the problem.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 04-15-2024, 03:30 PM   #5
Name:	Screenshot 2024-04-15 at 4.27.36 PM.jpg
The white line is where I put the shim to squeeze that tab over to the right so it made contact with the bottom spade of the switch.
Old 04-15-2024, 04:35 PM   #6
Good job.
Attachment 298726
Good job. (There ought to be a way to get a more secure contact.)
Larry
Old 04-16-2024, 03:09 PM   #7
2plus1's Avatar
Just a WAG Elliot but in 2011 they were not using LED bulbs. I suspect the original bulb was longer and forced the contact.
Paul
Paul / Carole Ann and 'Monte' the Goldendoodle
2023 Rockwood Ultra Lite 2608BS
2020 Rockwood Mini Lite 2511S
2017 Rockwood Mini Lite 2502KS
2012 Ram 2500 6.7L Diesel
2plus1 is offline   Reply With Quote
Old 04-16-2024, 03:11 PM   #8
I did still have the original and it wasn't longer. Good deduction though.
dometic, fridge, light
