Old 02-26-2020, 07:08 AM   #1
Draw That Battery Down To 10.5 Volts!
I attended an RV show this past weekend that included several technical seminars. While I attended several seminars, I really looked forward to the 60 minute discussion around lead-acid batteries, both flooded and AGM.
The RV battery expert instructing the seminar made reference several times to drawing lead-acid batteries down to 10.5V. When I pointed out to him that all of the DoD charts that I have seen indicate that a flooded battery should only be drawn down to 12.0 to 12.1 volts (50%) or you will damage the battery. He responded by saying that you can actually draw a flooded battery down to 10.5V with no problems. He stated this "fact" several times during the seminar and I found this to be bizarre.
So, has anyone else heard that you can draw a flooded battery down to 10.5V?
Witness_Protection is offline   Reply With Quote
Old 02-26-2020, 07:21 AM   #2
Watching this as I agree with you about the 12 voltage.
Old 02-26-2020, 07:31 AM   #3
Herk7769's Avatar
10.5 volts is a recipe for early replacement.
Every source I have says no further than 50% of bank capacity (or 12.1 volts).
The graph shows battery cycles (number of times it can be discharged and recharged) as a function of percent of discharge with 10% the highest and 100% the lowest number of discharge/recharge cycles.
As you can see, it drops off rapidly after 50% (about 12.1 volts).
Name:	battery Life as a function of charge discharge cycles.jpg
ID:	223984   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 02-26-2020, 07:48 AM   #4
Trailer Park Supervisor
NJKris's Avatar
I abide with charts/graphs Herk attached. Makes me wonder how the tech seminar guy got the 'expert' moniker. Expert in battery sales maybe??
NJKris is offline   Reply With Quote
Old 02-26-2020, 08:20 AM   #5
There's a difference between the voltage when you're pulling on the battery and the voltage the battery will recover to once the load is gone.
If you pull a lead acid battery down to 10.5 VDC under load, turn off all load, and wait an hour, you might just see the magic 12.0 to 12.1 volts.
johnbryanpeters is offline   Reply With Quote
Old 02-26-2020, 08:32 AM   #6
KyDan's Avatar
I check my battery voltage under light load. IE: there is always something on in the trailer unless the battery switch is off.
I try to limit my discharge to 12v as many have mentioned.
It always seems the "first half of charge" lasts longer than the remaining.
This makes me think 12v under load is already below 50%
I've found the "experts" at some seminars such as you find at RV shows and State Fairs sometimes are blowing smoke to make themselves sound smart and to sell product.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-35
Old 02-26-2020, 08:40 AM   #7
"To get accurate readings, the battery needs to rest in the open circuit state for at least four hours; battery manufacturers recommend 24 hours for lead acid."
https://batteryuniversity.com/learn/...tate_of_charge
Old 02-26-2020, 08:48 AM   #8
I know the conventional wisdom (especially on this forum) is never draw a battery down that low but real life experiences of using lead acid batteries for 50+ years in many different applications say differently, especially in the last 20 years.
I'll leave it at that.
Days Camped: '17=30 '18=51 '19=58 '20=88
Old 02-26-2020, 08:50 AM   #9
KyDan's Avatar
That's fine in a lab but I'm out in the woods and it's dark and I'm laying in bed watching a Tom Selleck movie on battery power.
It's not real convenient to turn everything off and wait 24 hours to check battery voltage.
So I take a look at my voltage under light load and decide if it's gonna be quiet in the morning or whether I'm gonna be running the genny.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-26-2020, 09:34 AM   #10
Herk7769's Avatar
Here is an excellent article on lead acid batteries.
https://www.progressivedyn.com/service/battery-basics/
As stated prior, battery voltage drawdown has a direct relationship to battery longevity. That is, the number of times it can be charged and discharged before it is used up and must be replaced.
Only you can decide whether discharging to a minimum of 20% capacity remaining and the resultant reduction in battery cycles is "worth it" to you.
Most everyone agrees that discharging below that is to be avoided.
Herk
Old 02-26-2020, 09:55 AM   #11
Totally agree with KyDan. I would bet no one camps overnight on battery power, then wakes up, disconnects the batteries to remove any load. After doing that, wait 24 hours for things to stabilize, then check the voltage to see if they need charging. Not too likely IMHO! Most people would look at the volt gauge or battery monitor, see it down to below about 12.1 with just the light load of propane sniffers, fridge boards ect and just charge up the battery bank. Jay.
2016 Rockwood 2504s.
TV: 2014 Silverado 1500 double cab.
Jay2504 is offline   Reply With Quote
Old 02-26-2020, 10:40 AM   #12
Drawing a battery down to levels below 50% may reduce life and cycles but how many times is really important.
If you draw your battery down even 10 times a year you may only reduce the life by a small amount. Think about it. 10 x5 years is only 50 low cycles in the whole life.
MtBiker is offline   Reply With Quote
Old 02-26-2020, 11:10 AM   #13
Something always overlooked in these conversations is how long the battery remains at it's low state of charge.
If it's run down then recharged ASAP, that's entirely different than running the battery(s) down on a weekend of boondocking, driving home and parking the RV for a week before recharging.
I wonder how many people with golf carts worry about the "50% Rule"? Especially golf courses.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 02-26-2020, 12:03 PM   #14
NMWildcat's Avatar
X2.
But I do enjoy following all the experts in the forum and the detailed analysis of amps, volts, charts, graphs, and 27 8x10 color glossy pictures with circles and arrows and a paragraph on the back
Then I go out boondocking and 'abuse' my batteries horribly on a daily basis. And yes, after about 5 years, I have to replace them due to said abuse......
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 02-26-2020, 12:29 PM   #15
Originally Posted by NMWildcat View Post
X2.
Ad those who "follow the rules" and baby their batteries may get 6 years out of their lead acid batteries.
2004 Nissan Titan
Old 02-26-2020, 01:34 PM   #16
this is the exact reason I installed battery monitor so it tellls you exact state at any instant without having to wait or overshooting on the low side.
bigred123 is offline   Reply With Quote
Old 02-26-2020, 01:45 PM   #17
Mr. Dan's Avatar
X2.
You can get anything you want at Alice's restaurant.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 80; booked = 14
Old 02-26-2020, 01:56 PM   #18
NMWildcat's Avatar
And there it is . I guess that dates us......
Old 02-26-2020, 03:39 PM   #19
Lifesylers
Bottom line is I don't really give a damn, I just go about my life everyday and not let trivial things like batteries consume my time. Diesel engine is another story, maintain the hell out of that, big price difference in cost for 4 batteries than shorter life of engine.
Lifestylers is offline   Reply With Quote
Old 02-26-2020, 03:40 PM   #20
I always liked that Arlo Guthrie fellow!...
battery
