Possibly I've missed something in all the replies, but having just installed 6 solar panels on my Rockwood Minilite, here is what I have to say. First be certain that 3/8 inch plywood is what you have. Generally with the structural panels that Rockwood and others use, this thickness is more like 3/16 inches. If that is the case, then it is important to figure out an appropriate attachment method that will hold in this type of material. Regardless of what you do, you certainly don't need 1 1/4 inch screws, only need to be long enough to accept your bracket and get through the plywood layer, however thick that is. What eventually worked for me, I used a 3/4 inch self tapping metal screw, not the type with the flared ends, and initially used these to secure the brackets, but even being very careful, I stripped a number of screws. So I went back, took out all the screws, and epoxied wooden golf tees into all the holes, (trick I learned working on alpine skis), once the epoxy set up, went back drilled a small pilot hole and again secured the brackets with the same screws. Worked very well, and the panels appear to be very secure.
I made my own brackets, because I wanted to have a larger bracket holding more screws, so less stress on each screw, and as I recall, the cost was less than if I had bought brackets. I bought z shaped aluminum in as I 3 foot lengths or maybe 4, then cut these down to use.
But in summary, make sure how much plywood you have to screw into and go from there. Also, attaching to the rubber roof with tape, is trusting that your rubber roof membrane is not going to separate from the substrate under it, I personally would not want to gamble on that one.
Good luck, I love my solar system.
