Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-13-2022, 12:13 PM   #1
NCBBA11043's Avatar
Dual Mode (Lead-Acid / Lithium) Converter-Charger
I had to replace my WFCO converter/charger a little while ago, and I wanted to buy one that would work now, and in the near future when I upgrade to lithium batteries. Couldn't find what I needed.
Does anyone know if there is a converter/charger available that has a multistage charging profile that would work for both lead-acid AND lithium?
All of the chargers that I have seen are for one style of battery or the other. I had thought I saw a switch selectable charger that would handle both, but can't find it now. I've seen some lead-acid chargers that the manufacturer states can charge lithium, but you need to do this manually to fake out the charger - not a great solution.
Anyone know of one? Thanks!
2015 Silverado 3500HD CC Long Bed Diesel
2016 Silverback 33IK
NCBBA11043 is offline   Reply With Quote
Old 01-13-2022, 12:30 PM   #2
Hi, Ray from Love Your RV just posted a video with a new WFCO model that will auto-detect lead or lithium and adjust the charge mode accordingly
https://youtu.be/oEutPVI-2R8
2012 Rockwood Roo 233, 2017 Dodge Durango 5.7
200w Suitcase Solar panel
Victron SmartShunt 500a, Victron 100|20 MPPT, Victron 800w Inverter
0rion is offline   Reply With Quote
Old 01-13-2022, 12:36 PM   #3
You don't mention the amperage of your system. It would be helpful to know the model number of your current converter or your Power Center as the converter may be part of this. You may need to replace the Power Center. This is not super expensive nor difficult to do.
Rockwood Geo-Pro 15TB on order
W5CRE is online now   Reply With Quote
Old 01-13-2022, 01:28 PM   #4
This is what I replaced a WFCO8955 with, simple to set for lithium.
https://www.bestconverter.com/PD-465...l#.YeBu9PxOmCg
latner is online now   Reply With Quote
Old 01-13-2022, 02:35 PM   #5
sdelam's Avatar
I looked into the best converter before the holidays, sent an email with some questions and never got a response. Found the new WFCO Auto detect stuff and think i will wait until its available.
https://safe.menlosecurity.com/doc/d...7319bc88df8ac5
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 01-13-2022, 03:37 PM   #6
NCBBA11043's Avatar
It's a WFCO 9855. I already replaced it, just looking for recommendations for future. Thanks.
p.s. - when the converter craps out and you're on the road and can't wait for a part to get shipped and have to rely upon local vendors - it is VERY expensive.
Old 01-13-2022, 03:43 PM   #7
NCBBA11043's Avatar
You need an account to see this info on the web . . .
Any other places that show this?
Old 01-13-2022, 04:22 PM   #8
https://wfcoelectronics.com/product-...f-9800-series/
The WF-9855LiS has a switch for lithium/lead acid
Old 01-13-2022, 04:38 PM   #9
The power max boondocker converter charger will handle FLA,AGM and Lithium batteries . they have settings you can change charge rate and time and work for all batteries . one thing to consider is when towing and hook to truck you can damage alt trying to charge lithium batteries with out some type of charge controller so as to not over work you truck alt
MR.M is offline   Reply With Quote
Old 01-14-2022, 06:32 AM   #10
Try The WFCO WF-8955PEC-B-LIS
vic1954 is offline   Reply With Quote
Old 01-14-2022, 12:38 PM   #11
My information matches latner's. I was looking to replace my current WFCO charger, the WF-8955MBA, with one that supports LiFePO4 batteries. I called up WFCO (877-294-8997 in case you want to give them a ring) was connected to their tech support, and told them what I wanted to achieve. He said that if I wanted the ability to charge both lead acid as well as LiFePO4, then to go with the WF-8955LiS. If I am only interested in LiFeO4 moving forward, then the WF8950L2-MBA is the one that I would want.
In the WF-8955LiS it has a switch that lets you choose between lithium or lead acid. In the lead acid mode it will 3-stage charge at a maximum of 55 amps. In the lithium mode it will 2 stage charge at a maximum of 50 amps.
In the WF8950L2-MBA, it is a 2-state charging cycle at a maximum of 50 amps.
2020 Heritage Glen 22RBHL
Quadna71 is offline   Reply With Quote
Old 01-14-2022, 12:40 PM   #12
Here's a link to the manual for WFCO's WF-8955LiS. If you open it up, page 7 is where it describes in detail how the lead acid 3-state charging profile operates and the lithium 2-state charging profile description starts on page 8.
https://wfcoelectronics.com/wp-conte...-Manual-RP.pdf
Old 01-14-2022, 01:54 PM   #13
Amazon 2-Day shipping
That's what Amazon 2-day shipping is for. Had a converter sent to me in Ohio. Had some ABS pipe fittings sent to me in Virginia. Other stuff too, that I can't remember.
Larry
Larry-NC is online now   Reply With Quote
Old 01-14-2022, 02:10 PM   #14
sdelam's Avatar
Odd, i don't have any special accounts. Here is a link to WFCO page with the docs.
https://wfcoelectronics.com/product/...ad-series-mba/
converter
