Originally Posted by Guitar picker
My generator wouldn’t run for over 5 min and then would throw a number 25 code. After a lot of troubleshooting I found out it was sucking air somewhere. I vacuum checked the fuel line it checked out ok. Tested both fittings they checked out ok. Pulled the pick up tube out of the fuel tank and found a 2 inch crack at the top.
Clean it and solder the crack. Use a Bernz-O-Matic style torch. If you don't have one, you could do the job over the gas-range burner.
If it's standard tubing with a compression fitting, just buy a foot of it and cut to length. You will probably need a new compression ring, too. Both of these are available at Lowe's, Home Depot, and most hardware stores.
