Old 02-14-2020, 06:41 PM   #1
electrical dummy
I am looking for some advise on the following. We have a 2016 Cherokkee 304b travel trailer. It currently has the orginal class 24 12volt battery. I want to change the battery and while doing so make the trailer more compatable to dry camping on occasion. When we dry camp the DW likes to use the tv 70watt and Dvr 95 watt and one of the 12 volt lights. Of course you also use the igniters on the refrig. and furnance. This usage is approx. 7 hour in the evening.
I have a 1000 watt solar panel with conttroler and a 2500 watt inverter.
I could not find the amps. on the above items. My questions are;
Batteries wet or agm
batteries (2) 6 volt or one 12volt
batteries how many Amp Hrs
Any information would be greatly appreciated as I know zero about electric much less solar.
THELMALOUIE is offline   Reply With Quote
Old 02-14-2020, 07:00 PM   #2
Typically 6 volt golf cart batteries will give you approximately 220 amp hours linking two In parallel. Figure you can use half of that before having to recharge the batteries. To clarify do you have a 100 watt solar panel or do you have several panels equaling 1000 watts? If you have a thousand Watts of solar power sounds like you have more than enough for most situations.
notTobyG is offline   Reply With Quote
Old 02-14-2020, 07:04 PM   #3
You値l probably want the two 6 volt golf cart batteries wired in series, not parallel, so you値l have an output of 12 volts.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 02-14-2020, 07:05 PM   #4
1 1000 watt panel
Old 02-14-2020, 07:19 PM   #5
Oops you're correct!
Old 02-14-2020, 07:28 PM   #6
I have never seen a 1000 watt panel. I have seen a few 1000 watt systems which frequently are 10 panels hooked together. I have two 150 watt panels but most panels are 100 watts each. A 1000 watt panel would be very large.
BarabooBob is offline   Reply With Quote
Old 02-14-2020, 07:49 PM   #7
The more battery storage the better. We have 4 six volt batteries.
You need the most you can get.
AGM generally are less forgiving of abuse and more expensive. Two lithium would give you 200 amps but the cost is high. Likely you need a new converter.
P=IV. 100 watts is 12.5 volts times I amps. So 100 watts is about 8 amps. Rooftop solar is generally about 25 amps a day per 100 watt panels on a good day.
If you use an inverter there is a 10-25% loss of power in the conversion that has to be figured into you calculation of what is needed.
Man, 1000 watts of solar is a ton! No walking on that roof!
tomkatb is offline   Reply With Quote
Old 02-14-2020, 08:15 PM   #8
Originally Posted by THELMALOUIE View Post
1 1000 watt panel
Is that panel approx 25 ft x 12 ft ?
If not, then that panel is not a 1000 watt panel.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 02-14-2020, 08:29 PM   #9
...far N Georgia!
formerFR's Avatar
I think 2 GC2 Golf Cart batteries are in your future, wired in 'series' to give you 12 volts... you'll not really 'need' solar, though it's nice to have for the few hours the sun might shine for you, but it's not going to make any huge impact - the batteries are what is going to allow you to have a comfortable 7 hours of enjoyment each evening.
Then, use the small generator to recharge the batteries the next day, for several hours...
done!
The Turners...
'14 Thor Palazzo 33.3 compact diesel 100k+miles since '14... US, Alaska, Canada...
AND a '14 Gulfstream Amerlite
AND a '07 ForestRIver Rockwood : )
formerFR is offline   Reply With Quote
Old 02-14-2020, 08:55 PM   #10
I was thinking the same thing. Then I began to wonder how large a panel that really would be.
Old 02-15-2020, 01:05 PM   #11
I had a chance to check today. It is a 100 watt panel
Old 02-15-2020, 01:06 PM   #12
It is a 100watt panel Sorry for the mis info
Old 02-15-2020, 01:20 PM   #13
SlowrideHD's Avatar
A 100 watt panel isn't going to supply much more than a trickle charge. I have a dozen 265 watt panels at my cabin, so it really takes a lot of solar to do much good.
A couple of Trojan T-105 six volt batteries will give you 12 volts and about 110 amps of useable power before they draw down to 12.1-12.2 volts at rest. That is considered 50% of your total power in the batteries and you don't want to draw them down much more than that.
It would be great for you to have 400-500 watts of solar. The thing about topping off your battery bank with a generator that runs for an hour or so is that the battery bank never has a chance to get far out of "bulk" mode and into a "float" mode. That gets your batteries back up to near 100%
Also look at a MPPT solar control if getting more panels. A PWM is ok for a single panel but not ideal for efficiency.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 02-15-2020, 01:22 PM   #14
Flybob's Avatar
No problem. You would need a very large RV for a 1000W panel if you could find one.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-15-2020, 01:41 PM   #15
GoneSouth10's Avatar
Dammit - I just spent 4 hours searching Amazon for that 1000W panel!!!
2015 Berkshire 34QS
GoneSouth10 is offline   Reply With Quote
Old 02-15-2020, 02:05 PM   #16
As another has said 100 watt panel is only going to replace a few AH's back into the battery(ies). I have a 340 watt panel that I use on a pole that is anchored to the front or back of the trailer or with in a 75ft. radius of the trailer depending on where the sun is. This way I get the max sun possible. With my system I'm able to replace all AH used up to my max of my two 6v batteries (110Ah = 50% of 220Ah) . Obviously provided it is sunny. My biggest Ah drain is my Keurig 4 to 10 cups a day and running my Treager smoker 3 to 8 hours a day depending on the cast of characters each trip. I have been out up to 5 days at a time and never have had to fire up the Genie.
Old 02-15-2020, 02:53 PM   #17
What make is your panel
Old 02-15-2020, 03:07 PM   #18
LG when I put solar on my house I bought an extra panel. $300 for the panel
Old 02-15-2020, 03:25 PM   #19
Thanks I will look at that
Old 02-15-2020, 03:42 PM   #20
Flybob's Avatar
Be aware that all 100W ( or any other panel size) are not equal. Check efficiency and voltage out. Renogy has some good panels and good information. If you are buying a controller, get one that is 30%-50% larger than you think you need. That way you can add panels ( even unmounted) without buying another controller.
TST Tire Monitors
2 100W solar panels
