Old 04-25-2021, 02:41 PM   #1
Electrical Issue
Hello, we have a 2021 Salem 273qbxl and we are having electrical issues.
The lights in the main bedroom and some of the lights in the main trailer do not work but many others do as well as all major appliances.
Any ideas of why? The fuses are all fine and our battery is fully charged and good.
We currently have the battery plugged into our home power source.
Thank you for the help!
ReddyFam is offline   Reply With Quote
Old 04-25-2021, 03:57 PM   #2
david_reaves's Avatar
If all the fuses are good, then maybe you have a loose connection at the converter, at a wall switch, or the main control panel if the lights switch there.
An easy way to check-- if there is a switch, is to pull the switch cover & switch out, then check the terminals of the switch with it in the "off" position. If the switch is getting current then it should read somewhere around 12-volts. You can also pull one of the non-working lights and check those (with any switches on) to see if there is voltage there. You can work your way out, checking voltage from the converter, to switches, and the lights, or start on the outside edge and work your way in from the lights. Working from the converter out is probably better... if there is a open connection near the end of the circuit then that may make it look like there is a problem closer in, too.
David & Elise
Windjammer 3001W
RAM 3500 SRW
david_reaves is offline   Reply With Quote
Old 04-25-2021, 06:18 PM   #3
Check to make sure the switch on the fixture itself is on. Most of the round LED lights have a switch at the center of the light. Hope this helps.
Papa Roo is offline   Reply With Quote
electric, electrical
