Originally Posted by bubbles
Well, you've changed everything associated with AC power (microwave etc.). Your issue is DC power.
As stated, your power cord, your inlet, your breakers are all associated with shore power (AC power/120 volt stuff). Your microwave and ceiling fan work on 120v shore power. All the other stuff (LED lights, jacks, stereo, thermostats, control boards, etc., run off 12 volt circuits (DC power) - meaning off your battery. It is highly probable that you have a battery disconnect switch in the disconnected state. People do this to keep from discharging their battery when their unit sits a while without being plugged into shore power. Check for a battery disconnect switch and make sure the battery is connected. If it IS and things still don't work, use a multi-meter/volt meter and check the level of charge in your battery.
