09-18-2019, 05:41 PM
Electrical panel
I just bought a 2020 arctic wolf 245rk4 and used the electrical while filling the camper with my stuff. 2 days later I go out and pop the gen breaker. I assume it’s a generator breaker but we do not have a generator. As soon as I flip the breaker it pops again. What is causing it to blow?
09-18-2019, 05:45 PM
Please post a photo of the panel and the breaker you are referring to as a generator breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-18-2019, 05:54 PM
Are you plugging your RV into GFCI outlet?
DYNAMAX 2016 FORCE HD
09-18-2019, 06:20 PM
Yes
09-18-2019, 06:24 PM
Try plugging the RV into a non GFCI protected outlet in the house. Some GFCIs do not play well together if connected in series.
TST Tire Monitors
2 100W solar panels
09-18-2019, 06:25 PM
Originally Posted by Sandy1
Yes
Yep, that may be your issue.
09-18-2019, 06:31 PM
09-18-2019, 06:33 PM
We used it all weekend with out a problem. Changed the pig tail to a new one and now it blows even when going back to the original cord same outlet we have had multiple other campers plugged into
09-18-2019, 06:49 PM
We had the camper plugged in and had no issues this weekend. Changed the pigtail we were using and now even when going back to the original pigtail it pops. Also figured out “gen” doesn’t mean generator
09-18-2019, 07:50 PM
So we did some research it’s the breaker for our inverter. We had it off. Once we turned it on and turned the breaker back on it was fine as soon as we shut the inverter off it popped the breaker again. Still don’t understand why it need ms to be on when plugged in however we are going from a 50 amp camper to a 30 amp pigtail to an extension cord
09-19-2019, 10:10 AM
A breaker labeled as GEN in the power panel usually means 'General' as in general receptacles (non-gfci). Is that breaker a gfi breaker?
What is the make and model of your inverter?
You say that you switched 'Pig-Tails'. Why did you switch?
It's sounding like the pig-tail is the problem since it worked before switching it out.
Gotta go campin!
09-19-2019, 01:12 PM
We were using the long cord from the camper and switched that to a pig tail as we didn’t need 50feet of the heavy cord. He thought switching them back to the original set up would solve the issue but it still blew. We found that we have to keep the inverter on and it doesn’t blow. But when we shut the inverter off it blows when plugged into the house.
09-19-2019, 01:23 PM
It sounds like the inverter transfer switch is switching the hot to ground or neutral when you turn the inverter off.
What happens if you turn the inverter on and close (turn on) the breaker and then switch the inverter off? Does it trip the breaker immediately? CAUTION! If you haven't already tried this, DON'T!
Do you know what the make and model of the inverter is?
Gotta go campin!
09-19-2019, 01:44 PM
I’m not sure of the year it’s a sure sine 1000watt
I believe we tripped it when we turned the inverter off and didn’t know it until we changed the cords a couple days later.
09-19-2019, 02:01 PM
Please provide the make and model # of the inverter. It would help to be able to see how the transfer switch works ( manual/automatic).
TST Tire Monitors
2 100W solar panels
09-19-2019, 02:12 PM
You should run your heavy cord as much as possible. Adding in a small lightweight extension cord can lower your voltage under load.
You should try not to run the air conditioner with an added cord.
09-19-2019, 07:29 PM
Wf5110r sure sine 1000w. We are blowing the gfi in the house. When the inverter is turned off
