Old 10-21-2020, 11:25 AM   #1
Red face ems surge protector
I am wanting to install a EMS-HW50C in my 2016 315RST Prime Time Crusader and find little room behind the converter. Is there a better place to install it?
Thank You
grpahelmer is offline   Reply With Quote
Old 10-21-2020, 12:05 PM   #2
How about where the power enters you camper.
2020 Flagstaff Micro Lite 22FBS
Old 10-22-2020, 06:24 PM   #3
ems surge protector
I put mine behind the converter. That was definitely the easiest place for the install. I disconnected the wire from main circuit breaker and connected that to the feed terminal on the EMS. I then added a short wire from the EMS out to that circuit breaker. The whole install took less than an hour. It doesn't need too much room. Mine was under the refrigerator. I pulled out the circuit breaker panel and the access panel and that gave me access from two sides.
john221us is offline   Reply With Quote
Old 10-22-2020, 07:07 PM   #4
I fabbed up some brackets to mount the EMS above the converter.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 10-22-2020, 10:01 PM   #5
Thank you
Old 10-22-2020, 10:02 PM   #6
That may work thanks.
Old 10-23-2020, 01:14 PM   #7
What guage wire did you use for this and can you just buy a short piece.
Thank You
