Old 02-16-2020, 08:30 PM   #1
Extra battery
Would I need a special hook up if I wanted to put a second 12 volt battery on my toy hauler just to help out occasional boondocking? Thanks. You guys are my go too for this stuff!
blucat1953 is offline   Reply With Quote
Old 02-16-2020, 08:54 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Just need to buy extra cable to hook batteries up. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 39
aceinspp is online now   Reply With Quote
Old 02-16-2020, 09:40 PM   #3
Buy two cables from an auto parts store. Wire them in parallel and use 2 batteries all the time.
Old 02-16-2020, 09:49 PM   #4
No special hook up is needed, just a pair of cables; positive to positive and negative to negative. Whatever battery you add should be identical in size, type, and specs as the current battery and preferably the same age.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
woo10-210 is offline   Reply With Quote
Old 02-16-2020, 11:11 PM   #5
CincyGus's Avatar
Bluecat, since you have a lower number of posts, I'm going to assume, maybe incorrectly, that you have a new RV. If so and the battery is new also, just do as everyone above advised. If you have bought a used trailer and the age of the battery is not known, understand that having two batteries of different ages hooked together will limit the batteries somewhat by the older battery if it is not in great shape. I only mention this because If that is the case, It may be better in the long run to get two batteries new and you know they are of the same age and same strength.
Good Luck in your project. It's worthwhile for those that spend time of grid!
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
battery
