Old 02-25-2021, 01:32 PM   #1
F150's 7.2 kW "Pro Power Onboard" 30A/240V outlet
Regarding the F150's 7.2 kW "Pro Power Onboard" 30A/240V outlet...
Is that connection (NEMA L14-30R) compatible with a 50-amp RV's connector?
I know that it's a no-no to plug a 30-amp RV into 240W (although I bet people will start doing that), but will this thing work with the 50amp units?
PodGeek is offline   Reply With Quote
Old 02-25-2021, 04:01 PM   #2
If the 240V output is two 120 volt legs that measure 240 between them, and has a neutral, you can use it for a 50 amp service although you'll be limited to the max wattage of the Pro Power itself.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 02-25-2021, 04:10 PM   #3
Guess one would have to contact Ford for that specific information. I haven't found anything on the web yet.
Old 02-25-2021, 04:45 PM   #4
llr
If it is 240V then for 30 amp RV use you would need adapter that leave one hot lead out. They make them to go from a standard 240v 50A to 120v 30A, not sure if they make one from that outlet or if you need to make your own.
I doubt if it would not be 240V however, I have not seen an RV that uses 240V for anything you could use that outlet for a 50A unit either way. The only risk if they are 2 120V in phase is overloading the neutral wire. since 50A 120v is 6,000 watts and the generator only being 7,200 watts (probably surge), the odds of causing any issues is almost zero.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 02-25-2021, 05:12 PM   #5
This truck was made for Contractors who could well be running 240 volt equipment, like a Mig Welder. I doubt the outlet is a 50 amp outlet but rather a 30 amp 120/240 twist lock. Think outside the box.
Since the output is rated for 7.2 Kva I'm going to think it's 30 amp on the 240 volt output.
Old 02-25-2021, 06:41 PM   #6
All the pictures I see on the web show a NEMA L14-30 receptacle in the power station, so you'll need an adapter for whichever amp service your RV have.
I have a couple of "generator" adapters for both 30 amp and 50 amp RV's because my generator has the L14-30 receptacle on it.
Gotta go campin!
Old 02-26-2021, 11:26 AM   #7
... I doubt the outlet is a 50 amp outlet but rather a 30 amp 120/240 twist lock....Since the output is rated for 7.2 Kva I'm going to think it's 30 amp on the 240 volt output.
Originally Posted by Bama Rambler View Post
All the pictures I see on the web show a NEMA L14-30 receptacle in the power station, so you'll need an adapter for whichever amp service your RV have....
It's definitely 30A/240V. Bama Rambler...do you really think this can be used with a 30A RV/TT even with an adapter (as can be done at RV pedestals with 50A connections)?? I found this:
It is important to note that you can not plug your 30-amp RV into that plug because it puts out 240 volts. RVs are intended to run on 120 volts. At this moment you can only plug into the standard 20 amp outlets.
https://camperreport.com/2021-f150-ford/
Old 02-26-2021, 01:24 PM   #8
llr
With the proper adapter you will be fine. A 30A RV adapter will only use 1 hot, neutral and ground. The 2nd hot will not be used.
Each hot is 120v to neutral, 240V is between the 2 hots.
Old 02-26-2021, 02:07 PM   #9
JROtexas's Avatar
Pro Power Onboard
There are three levels of power depending on your choice of engine and options: 2kw, 2.4kw, and 7.2kw.
The Ford brochure says:
The 2 and 2.4 kw units have two 120v 20a outlets.
The 7.2kw unit has:
Optional PowerBoost / Outlets in bed: Four 120V 20A, one 240V NEMA L14-30R
My guess is that if you want any of these you'll need pretty deep pockets.
Here's a link from Ford:
https://www.ford.com/cmslibs/content...er_SP_C113.pdf
Jeff
2019 Rockwood Mini Lite 2506S
2014 Ford Expedition 4X4 Limited
Andersen WDH
JROtexas is offline   Reply With Quote
Old 02-26-2021, 08:29 PM   #10
It's definitely 30A/240V. do you really think this can be used with a 30A RV/TT even with an adapter (as can be done at RV pedestals with 50A connections)??
As mentioned, with the proper adapter you can plug your 30 amp 120 volt RV into the power center. Generator to 30 amp RV plug only uses one hot leg of the L14-30 plug.
Gotta go campin!
Old 02-27-2021, 12:49 PM   #11
Ok...I guess where folks run in to problems is when they plug their 30-amp RVs directly into older 240-volt dryer outlets that look like 30-amp 120-volt RV outlets or into dedicated RV outlets that some electrician/relative wired to 240 volts because it looks like a dryer outlet
f150, power
