Old 02-11-2019, 02:19 PM   #21
Adrian Gordon's Avatar
Originally Posted by NJKris View Post
If the parasitic loads continually drained the batteries, they would discharge to the point of damage. You don't want to go below 50% state of charge for the health/longevity of the battery.
How long will that take?
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
Adrian Gordon is offline   Reply With Quote
Old 02-11-2019, 02:23 PM   #22
Trailer Park Supervisor
NJKris's Avatar
Agreed Adrian! That would be a decent thing to do. Scott, if I recall, the switch turns, but can't recall if I pulled it out or not. One thing for sure, none of the other things are working in the trailer after I turned the switch, namely the lighting and inverter.
NJKris is offline   Reply With Quote
Old 02-11-2019, 02:25 PM   #23
NJKris's Avatar
Before changing up any wiring, I may re-connect and monitor to see exactly how long it takes to draw down the 2 6v batts, just for fun.
Old 02-11-2019, 07:30 PM   #24
Originally Posted by bedubya View Post
I installed my disconnect in the negative cable at the battery box. Radio station presets have no value, anyway, unless you are always camped in the same area.
You missed what I was saying. I installed a true disconnect at the battery box, in the positive lead of my A-frame.
I ALSO installed a power switch in the stereo power leads. The power switch in the stereo itself does not turn the stereo completely off. When there is 12V power to the camper, the stereo will turn itself on whenever there is a voltage change on the power leads. Hence the need to have an external power switch for the stereo.
Fred W
Old 02-11-2019, 07:32 PM   #25
NJKris's Avatar
Fred, if you stopped listening to Lady Gaga at level 10, you wouldn't be so startled when the stereo comes on!
Old 04-12-2019, 07:21 PM   #26
Originally Posted by babock View Post
My battery disconnect disconnects the battery from everything except the solar. This includes brakes and tongue jack. I don't want the solar powering 12V devices in my trailer with the disconnect off so it goes directly to the battery side of the switch. I do have a solar disconnect if I want it off too.
Know I'm a bit late to this convo....But, where is your solar disconnect? Did you add it or is it factory installed?
2019 Flagstaff E-Pro 14FK
JS Stanley is offline   Reply With Quote
Old 04-13-2019, 09:02 AM   #27
I have an array disconnect and the controller has one I put on it's output as well.
babock is offline   Reply With Quote
Old 04-14-2019, 01:40 PM   #28
Is it a GoPower?
Old 04-14-2019, 01:54 PM   #29
NJKris's Avatar
Hahahaha, Babock does not mess around with mass produced systems hawked by RV manufacturers. He has some home brew setup! In a good way.
Old 04-14-2019, 03:57 PM   #30
Originally Posted by JS Stanley View Post
Is it a GoPower?
Victron
battery, battery disconnect, factory
