Factory Installed Battery Disconnect
Hi,
We recently purchased a FR Wildcat 312QBX 5ver with a factory installed battery disconnect switch above the control panel in the pass through storage. Dealer tech said this battery disconnect will break power to everything inside the trailer...which it does appear to do.
By observation, we've figured out that some of the outdoor edge lights still work as well as the landing gear and stabilizing jacks.
Power to the awning is also cut by the battery disconnect...but according to the awning manual the awning should not work when connected to the TV with the ignition in the on position. My awning will unless the battery disconnect is pulled...so not sure the awning safety is working correctly. Anybody have experience with this feature?
We also would like to be certain that the emergency braking system is not affected by the battery disconnect switch and will function no matter which way the battery disconnect is configured. Has anybody tested this feature and already found the answer?
Thanks,
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
