Old 03-16-2024, 03:54 PM   #1
Fireplace and microwave no power
Just opened my 2018 Forest river wildcat 5the wheel and my microwave and fireplace are not working. Need help!
moxie2869 is offline   Reply With Quote
Old 03-16-2024, 04:40 PM   #2
ForestGump34DS's Avatar
Both are 120 vac....have you checked your circuit breakers? Do your other 120 vac items work....like the A/C, outlets, TV etc. ???
2022 FR3 34DS
2021 FR Wildwood Lodge 42FK
2017 Thor Chateau 24B
ForestGump34DS is offline   Reply With Quote
Old 03-16-2024, 05:36 PM   #3
Checked circuit breakers and nothing is tripped. I didn't try the a/c but everything else seems to be working.
Old 03-16-2024, 06:39 PM   #4
breaker can appear to be NOT tripped when they are tripped...
best to cycle the breaker all the way off/on
Plus use a multi meter to confirm 120v is on the breaker input Bar ... and output wire
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 03-16-2024, 07:23 PM   #5
bikendan's Avatar
From what I've read, there's a rocker switch for the fireplace/microwave so you don't use them at the same time.
Old 03-16-2024, 07:45 PM   #6
Mr. Dan's Avatar
What is the model number of this Wildcat?
Is it a 50 amp or a 30 amp unit?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 41; Booked for 2024 = 55
Old 05-28-2024, 02:46 PM   #7
My fireplace and microwave have no power. I have a 2018 Forest River 35WB 5th wheel. I have reset the GFI and nothing is happening.
Old 05-28-2024, 03:10 PM   #8
Georgia Rally Coordinator
aceinspp's Avatar
Have you checked the main circuit box it has re settable breakers for Mic and fireplace. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
aceinspp is online now   Reply With Quote
Old 05-28-2024, 03:12 PM   #9
Part-Time Campground Host
cboss's Avatar
Are you plugged into power?
If so is anything 120 working?
Is the pedestal circuit breaker on?
To trouble shoot this start at the pedestal and work toward the camper. You will need a multimeter and the know how to use it.
Let us know when you find the problem.
Craig & Cath
Days camped since 2015(retirement): 1725
cboss is offline   Reply With Quote
Old 05-28-2024, 03:45 PM   #10
Have you checked any of the suggestions mentioned since your 1st post on 3-16-2024?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-28-2024, 03:50 PM   #11
It's a 35WB - 50 amp
Old 05-28-2024, 03:51 PM   #12
We are plugged into power and everything else is working.
Old 05-28-2024, 03:52 PM   #13
Should the pedestal circuit breaker be on?
Old 05-28-2024, 04:46 PM   #14
I have learned from other post that on many models the microwave and fire place share a beaker in the power center. Turn it all the way off and back on.
Just a thought
MGD1961 is offline   Reply With Quote
Old 05-28-2024, 04:47 PM   #15
wmtire's Avatar
Yes, if you want 120 volt AC power.
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but I’m too Pora-Pora.
Old 05-28-2024, 04:52 PM   #16
I'm confused... if you are plugged into power and everything else is working, the pedestal breaker must already be on?
Old 05-28-2024, 04:52 PM   #17
Do you know where that breaker would be - we don't have a generator in our midel
Old 05-28-2024, 04:53 PM   #18
Sorry I thought maybe this was a separate breaker.
fireplace, microwave, no power, power
