Originally Posted by PhilFromMaine
I probably should not comment because I don't fully understand what you are describing. However, GFCIs only trip because of current leakage as detected at the GFCI. The GFCI compares the current on the positive and the neutral. If the difference is 4 or 5 milliamps the GFCI will trip. Any fault will be downstream of the GFCI, not upstream.
I'm a bit confused too.
Because the INverter was NOT plugged into the AC outlet for it to "sense" shore power, the INverter was never automatically transferring AC shore power to the outlets... hence the limitation of watts supplied by the inverter... that part I understand.
I don't understand why a high current device caused the GFCI outlet to trip?
Maybe the OP actually meant the circuit breaker on the INverter???
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
