Originally Posted by namusmc
Say what? Unclear on the concept here.
The use of the emergency start switch will put the coach and chassis batteries in parallel. It's just something that will eliminate the possibility of a bad/low charged coach battery when a 12 volt item will not function ie. steps, genny etc.. If the item functions when emergency start is switched that would indicate a low charged coach battery. If the item still does not function when switched that may indicate something other than a battery issue. It's just a tool that may or may not be useful if shore power is not available. 2 persons may be required to accomplish this. Of course, this is predicated upon having an emergency start switch. Every MH I have owned had one but I suppose there are units out there that do not.
