Doubtful even if a wiring schematic is available and it may be, that it is going to be much help. I would pull the LED lamps down from the ceiling and check for power at the wires to the lamps if not having done so. If there is no power, then I would pull the rest of the lamps and look for any possible bad connections. Since there are three wires going to the ceiling, one, if white and heavier may be the ground (neutral) wire, the other two wires of any color other than white or green might be fused wires coming from the converter panel 12V fuse section.
OK to go a little nuts!
