Old 07-02-2020, 11:38 AM   #1
FYI: switched 3.0A dual USB port
I have no experience with this but am ordering one. I like the on/off switch. That means I don't have to add one to prevent parasitic drain.
I don't know how efficient high-amp USB chargers are, relative to lower-amp versions. It may waste a few amps. Even if so, the difference in charge time for a phone is worth it to me.
ReviewMeta gives it a 4.8 score based on 51 reviews.
https://www.amazon.com/dp/B082PNLMDS
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
Old 07-02-2020, 11:49 AM   #2
Looks pretty cool! Just to make sure, you do realize that is not a "cigarette lighter" plug in, but a hard wire in dash mount?
NavyLCDR is offline   Reply With Quote
Old 07-02-2020, 01:18 PM   #3
Yes. I'm actually buying this one, a duplex fixture with a switched double USB and a standard 12V accessory outlet. It includes a fused connector.
I have the remnants of a three hole plate from which I removed something in the past. It has a 12V accessory port. I'll move the two from the new purchase to the three-hole plate, the result being two 12V accessory plugs and a double USB port.
I plan to mount that near the headboard of our bed to power our two CPAPs and to charge our phones near our bed. I may have to fuse the accessory ports separately. I'll make sure the wire feeding it is has sufficient capacity.
Old 07-02-2020, 01:26 PM   #4
That should work just fine.
I do find it humorous they chose to use a photo of a finger touching the on/off button that makes the outlet look HUGE (in comparison to the finger) or that is Tinkerbell's' finger!
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-03-2020, 09:56 PM   #5
Jack of All Trades
RJHuser's Avatar
You do realize, if that switch is an electronic switch instead of a mechanical switch, there wil be a small current drain to run the switch monitoring electronics.
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 07-03-2020, 10:28 PM   #6
I'll test it with an ammeter. If what you suggest is true, and if the current is enough to be concerned with, I have a bunch of extra switches I bought for the purpose of killing parasitic drains. I will not have accomplished my goal of not having to install a switch, but it's a better USB charger than I have now. And, the switch probably cuts most of the power consumed by the charger itself.
Edit: I had not thought of that and appreciate your pointing it out.
Old 07-04-2020, 06:16 PM   #7
larry2c's Avatar
One thing to be careful with - some older devices aren't made to be used with "fast charge" USB ports. My old (10 years+) Kindle is one example - it needs a slow drip according to Amazon.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 07-04-2020, 06:41 PM   #8
The battery still works on that thing?
Old 07-04-2020, 08:18 PM   #9
larry2c's Avatar
Amazingly and quite well! Kindle Touch that I got in 2011 - so technically only 9 years old Some days you just get lucky!
'11 F150 5.0
Old 07-04-2020, 09:47 PM   #10
The switched USB charger in question isn't a "fast" charger by any stretch of the definition. It's only 3.0A total, but that's faster than the standard ones in the trailer, I think.
Old 07-04-2020, 09:51 PM   #11
Correction: one port is 3.0A, the other is 2.0A. So, faster than many but not extremely fast, compared to newer types.
switch
