02-12-2018, 01:31 PM
Garage 50 amp service for new RV.
Our new RV unit will have 50 amp service installed in it. All our other ones were 30 amp units. I had a dedicated 30 amp RV outside plug for the current RV put in when the garage was built. I still have the 30 amp as I can have a place for my in-laws when they come up from Florida.
So now with the new unit requiring 50 amp service, I put one in for it.
This is the breaker panel in the garage. Using 6/3 with ground wire to outlet, 63' total run. 50 amp breaker combo is bottom left. 30 amp RV service breaker is bottom right. Main disconnect for the garage is in the main disconnect box close to the meter. Both house and garage main disconnects are in that separate panel box.
This is from the disconnect to the outlet.
Hot, Neutral, and ground from inside breaker. With ground and neutral to outlet.
Outside disconnect wired and cover in place.
Final installation.
Everything is ready and good to go for the new unit!
2018 Flagstaff 831CLBSS
2015 2500HD Silverado LTZ 4WD
02-12-2018, 01:35 PM
Looks fabulous. I'm looking at a 300 ft run. Expensive wire.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
02-12-2018, 04:27 PM
Did I miss the other post? The red hot line is on one leg of the main box. The black hot line is on the other leg of the main box. Is that what you mean? The white is the neutral, correct?
02-12-2018, 05:32 PM
Just as confused as you
I don't know which other post your asking about, but in your 3rd picture, red is Line #1, black is Line #2, white is Neutral, and the bare copper wire is ground.
It is wired like the center image in the picture below except the red and black are reversed, which doesn't matter.
Richard & Jill
02-12-2018, 08:10 PM
While I was replying to a post, it disappeared.
Thanks for the diagram, I have been saving info like that.
But it is working like it should, with 116 - 118 volts each line. Neutral and ground are correct. Hot lines red, and black should not matter as long as they are not the same feed out of the box. Is that correct?
Gary.
02-12-2018, 08:18 PM
The "other post" was deleted. I saw it but I think the author found an error in his post.
Buzz & Jo Wolf
02-12-2018, 08:22 PM
That is kind of what I thought too. No problems with it, just was wondering.
02-13-2018, 01:18 AM
Gary.
Yes, that is correct. There are a lot of diagrams and documents in the forums about 50 amp service for your RV. Also for 30 amp service for those interested.
The links below were compiled by another member of FRF.
Disclaimer: These links and articles were compiled by wmtire. He is a site team member of forestriverforums (FRF). If you give thanks, then give it to him. I had nothing to do with gathering the information, I’m just passing it along.
“I always recommend these following links to newer RV owners. It explains a RV's different electrical systems, as well as what works off of 120 volt AC vs. 12 volt DC. Not knowing your RV experience, The below is a copy and paste, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.” - wmtire
Basic electric:
Basic RV Electricity - RV Information (RV Maintenance)
https://www.rvtechmag.com/electrical/chapter3.php
RV Electric
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
More reading so you understand the different electrical systems of your RV.
Installing a dedicated 30 amp RV outlet at home:
How to wire a RV 30 amp outlet
Suburban water heater (if applicable to your RV):
Suburban's electric switch and much more
Suburban Water Heater Video Guides
Water Heater bypass/crossover valves:
NO (OR LUKEWARM) HOT WATER -Please read first
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
Propane Cylinders (Refilling vs Exchanging)
Propane automatic changeover regulator
The “12 Volt Side of Life” file is on Forest River Forums in the Library > Power and Electrical section in the light green bar at the top of the page and is a download and is found here. Forest River Forums - Downloads - 12 volt side of Life
Richard & Jill
02-13-2018, 04:07 PM
What is the need for 50amp power at home? I'd just use an adapter and use the existing 30amp service. Doesn't 30amp power runs A/C?
02-13-2018, 06:09 PM
Reply 50 amp
The install is very neat!🤙 I do question the two 50 amp outlets? The diagram didn’t come thru clear it mayanswer my question
02-13-2018, 06:18 PM
Some install 30 amp or 50 amp RV service at their homes so they can use the RV as a MIL suite for friends and family visits.
Richard & Jill
02-13-2018, 06:37 PM
I have 50 amp service on my RV, but I only ran a 30 amp service because I do not live in my RV when it is at the house. 30 is more than enough for all of my loads/uses. The single AC unit (alternate front & rear) I leave on for dehumidification purposes will only draw 20-22 amps when OAT is 90+. Thermostat set to 86 (82 actual) in winter and 90 (86 actual) in the summer months (6 to 9 of them).
02-13-2018, 07:00 PM
Install looks good. Is there a specific reason why you opted for a load center box, and a receptacle box?
Just curious.
2016 Salem 27RKSS
02-13-2018, 07:09 PM
I'm also wondering why you need a separate set of breakers outside for the power, since it's for your own use, not in an rv park, and you already have the double-pole breakers in the house.
but, I also question why you need a new separate dedicated 50a service supply to your new RV, parked right next to your home... it can run quite well on your existing 30a service ( you have someone living in it during very hot summers or very cold winters ? ) : )
The Turners...
02-13-2018, 07:23 PM
As an electrician I like the disconnect as not be plugging in camper under load. Outlet and camper plug will last much longer and no chance to get shocked by touching prongs when plugging in.
02-13-2018, 07:49 PM
Yes, 30 amp will run one AC. I see no need for 50 amp power at home unless somebody is living in it.
02-13-2018, 08:18 PM
Yes, this is the reason for the disconnect for the 50 amp outlet.
02-13-2018, 08:22 PM
I'm just OCD on things like this. No other reason than it works for me.
02-13-2018, 08:48 PM
Georgia Rally Coordinator
Even if someone was living in it 30amp will do the job and running only one ac done it many a time traveling when 50amp not available. Seems like a little over kill to ad when you already had 30amp. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
02-13-2018, 08:55 PM
My hands are already hurting just thinking about managing that gauge wire in a box with breakers/receptacles.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
