I have a small Generac generator (1200). Is there a step I'm missing when I connect it to my Cascade? With all power off in the camper, as soon as I connect, the genset overloads and shuts down. It shows it has an open ground. Do I need to ground to the camper frame?
Welcome to the forum its a great place to get your questions answered. It could be your converter overloading the generator. You are only talking slightly over 10 amps of power from the generator. Just a guess on my part.
Retired Navy
2016 Flagstaff 26 FKWS
Turn off all breakers in the RV and try again. You need to determine if the gen is shutting down due to overload or ground issues. If it still shuts down with no load then it could be a ground issue. The link below will solve a ground issue if that is what it is. https://www.etrailer.com/Generator-P...rs/HU33FR.html
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
