Old 03-26-2017, 05:56 PM   #21
The above statement regarding the converter is not accurate. If the line and neutral wires are reversed where they are connected to the converter they will cause exactly this problem.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 03-26-2017, 06:13 PM   #22
SeaDog's Avatar
What was being described in post #16 sounds like the 12V side of the converter. I also agree you more then likely need to pull the converter to see the actual incoming power connections. OK there two many fingers in the pie so I will back away and look forward to hearing the final result and fix
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-26-2017, 08:19 PM   #23
I agree, too many fingers.
Andersen hitch
Old 03-26-2017, 09:50 PM   #24
Popup graduate
23dks's Avatar
The question about polarity in the initial post was on the trailer AC system. The converter plugs into the AC system and provides DC voltage and current as well as charges the batteries. The converter does not provide AC voltage or current for the trailer AC system. If the converter line and neutral wires are crossed, the converter will be connected with the wrong polarity but this can't affect the AC system, it will only affect the converter. The converter can only affect polarity of the DC system if the DC wires on the output are connected wrong.
2016 Wildcat Maxx 23DKS
2011 Silverado 2500HD Diesel
23dks is offline   Reply With Quote
Old 03-26-2017, 10:16 PM   #25
SeaDog's Avatar
On many units the converter is a general term used to describe the box for a unit that not only supplies 12V power but also serves as the distribution center for the 110V. Some rigs do have a as you say a "plug in unit" that only supplies 12V power others are hard wired to the incoming 110V and provide more then just 12V.
Retired Navy
Old 03-27-2017, 12:04 AM   #26
Popup graduate
23dks's Avatar
Thank you for the clarification. All the trailers I have worked on have designated the electronics that convert 120 vac to 12 vdc as the converter, hardwired or plug in. The distribution center, power panel, power distribution center, etc., houses the converter, the 120 vac breakers, and the 12 vdc fuses, and distributes power to the trailer.
Old 03-27-2017, 06:38 AM   #27
SeaDog is correct. The term convert is used for the entire unit that serves as the distribution panel as well as converting to DC 12 volts. For this reason it does matter if the line and neutral feeds are reversed. This would show up as reversed polarity in the outlets.
Andersen hitch
Old 04-06-2017, 07:02 PM   #28
Well guys, I really feel like a dumb a**. I had another guy look at this problem and he's a certified sparky. Nothing wrong at all. What it was was a bad tester. All the checks I had made were right and couldn't find a thing wrong.Neither did he.Thanks for all your help.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 04-06-2017, 07:31 PM   #29
Glad you got it resolved. Thanks for letting us know, I had wondered what you found.
For what it's worth, I've done worse. Lol
Andersen hitch
5er, electric
