Old 12-18-2015, 07:27 PM   #1
Generator
What size generator should I use to run my 30' 2015 Windjammer with 50 amp service? I am guessing at least 10,000 watts should work.
Thanks for any help.
peetersjeff is online now   Reply With Quote
Old 12-18-2015, 08:32 PM   #2
Windjammer travel trailer? Almost all toy haulers with 50 amp service and two ACs use 5500 watt Onans. Ours did and it would run both ACs all day long.
KFX450RXC is offline   Reply With Quote
Old 12-18-2015, 08:56 PM   #3
Blackhat6mike's Avatar
10K will run your whole house with left over. That's a lot of juice!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-18-2015, 10:41 PM   #4
bikendan's Avatar
10k, WOW!
That generator's noise level would run everyone out of the campground.
Old 12-19-2015, 12:56 AM   #5
Usually Confused Member
emm-dee's Avatar
I'm pretty sure 50 amps at 120 volts equals 6000 watts, so it would seem that anything over a 6000 watt generator capability would be unused/wasted power. At 110 volts it equals 5500 watts.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 12-19-2015, 08:54 PM   #6
Do what everyone likes on a forum like this: Tell us how much money you want to spend and we'll tell you what we want you to get!
(I meant what you need to get.)
Old 12-19-2015, 09:09 PM   #7
Oklahoma Proud
MillerTime's Avatar
That is total amps though??? 50 amp rv service is 50 amps per leg...so actually 100amps total. So op would probably still have some restrictions with a 10k genny, right?
My 6500 genny only has a 30 amp (twist lock genny 4 prong) service outlet on it and so that's what i installed on my house that we use it for. Can't do much with it being total electric in the country (water well and all) but its better than nothing!!
Old 01-16-2016, 11:00 AM   #8
Generator not starting
Have a new 300DS and tried to start generator to run for few minutes and would'nt start,in the past on my previously owed rv's I usually run them few minutes in the winter,however this generator won't start,I'm curious since this is a new unit is there somekind of a temp lock out? any words of wisdom are welcome
PM
locoengnr11 is offline   Reply With Quote
Old 01-18-2016, 02:53 PM   #9
Too Tall's Avatar
If you did not put stable protector in your gas that is probably the reason, your carburetor needs cleaning.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-18-2016, 02:55 PM   #10
Too Tall's Avatar
Is the champion 3100 quite enough to keep the neighbors happy?
USMC 68 -70
Old 01-18-2016, 03:40 PM   #11
bikendan's Avatar
I would be fine with it, as long as they didn't abuse generator hours.
I own an open frame Champion 3500w and would NOT be happy with that one in a campground.
It's WAY too loud for neighboring campers. That's why I use my Honda 2000w for campgrounds.
Old 01-18-2016, 04:05 PM   #12
rracer5's Avatar
Yup, that should work for you and about 3 or 4 of your fellow campers. And.....if you let them plug in, they can't complain about the noise a 10,000 watt genny will be making.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-18-2016, 04:25 PM   #13
There alot of areas and campgrounds that will not allow the use of open framed generators any longer,
Kevin & Judy is offline   Reply With Quote
Old 01-22-2016, 12:18 PM   #14
Too Tall's Avatar
Has anyone operated the Yamaha EU2000IS at 8000 +? I've read where they run good with re-jetting the carburetor? your thoughts appreciated!
USMC 68 -70
Old 01-23-2016, 12:36 AM   #15
Typical rule of thumb is to do down (leaener) one size in jet size for every 2000 feet. 99% of engines will run at high altitude without rejetting but you'll be wasting gas and will lose more than 3% in generator output for each 1000 ft gain in altitude.
Rejetting is VERY simple and even a former Marine can do it.
A properly jetted 2000 watt generator will only put out about 1500 watts at 8,000 feet....one that isn't jetted properly may put out 1200 watts max.
Drew
Army 1987-2003
Skyliner is offline   Reply With Quote
Old 01-23-2016, 01:41 AM   #16
Too Tall's Avatar
Thanks, I don't know, this one pretty thick but I did spend a few months in the motor pool so I think I can probably change the carb jet. That is, If it's not packaged so tightly that the thing has to be completely dismantled. I meant to say I heard they run pretty good without rejetting since the EPA has them running so lean already but I'm going to bring the proper jet along so I can do it on the road once I leave the flat land. Thanks for the help!
USMC 68 -70
Old 01-23-2016, 09:43 AM   #17
HONDAMAN174's Avatar
I use my Honda 2000 at 9k feet (I know different product). Point being, try it out before re jetting. I use my unit much more below 9k so I did not jet it. It does work well except for low voltage when I try to run microwave. So I can either bring my 2nd 2000 or turn off my PI EMS for the few moments it is running low voltage.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-23-2016, 11:02 AM   #18
Too Tall's Avatar
At 9000, does it run smooth, or is it hard to start or is the exhaust visible, like black? I really don't want to to have to change jets. I talked to a Yamaha dealer in Denver and he told me they sell the same unit that's sold at sea level. Yamaha doesn't even make a different jet, if a customer wants a high altitude jet, they get them after market.
USMC 68 -70
Old 01-23-2016, 01:17 PM   #19
Runs just fine. Just the microwave surge drops voltage below 104 for a moment and my EMS will kick off. No sense of hauling my other unit for just that. And yes the micro is a nescesity for my family-cleanest way to make bacon!
generator
