Old 09-27-2020, 12:49 PM   #1
Generator alert help
I am getting a "generator alert" screen. My generator has 80 hours on it and is exercised monthly, actually much more exercise that use. It starts easily but then shuts down and I get the alert on my screen. Does anyone have any ideas what I might check to resolve this issue before trying to find " an authorized Onan Cummings repair service" as the owner's manual suggests?
2015 Solera 24R
2014 Mercedes Chassis
Karter is offline   Reply With Quote
Old 09-27-2020, 01:02 PM   #2
Kanadian Kamper
kenandterry's Avatar
Check the oil level carefully. Some units will **** down if the level is considered to be low to protect itself from damage. Hows the air filter?
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 09-27-2020, 01:04 PM   #3
Checked both, they are fine
2015 Solera 24R
Old 09-27-2020, 03:17 PM   #4
Im assuming the error message on the screen is on some type of multifunction control screen. What error code is the generator itself flashing?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-27-2020, 04:00 PM   #5
rsdata's Avatar
I know my home generator is touchy on the oil... it starts than shuts down within about 10 seconds. Finally figured out that the oil has to be at the very top for it to stay running. If your rig is slightly off level perhaps it just needs a touch more oil if it is down any at all.
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 09-30-2020, 01:15 PM   #6
Might check the breaker on the generator you need to remove cover to see it. Also do you have 1/4 tank of gas or more.
retired on a mountain is offline   Reply With Quote
generator
