As stated the converter has a rating for the maximum number of amps it can push into a battery but it rarely gets to this max as the battery itself will limit the number of amps it will accept. The more fully charged it is the fewer amps it will accept.
The 13 amps you mention on the battery monitor are dc amps at 12 volts, about 156 watts. Assuming no loss within the converter it only need to draw 1.3 ac amps at 120, for the same 156 watts.
Your generator has a max rating of 5500 watts which is about 46 amps at 120 volts. Do your converter is putting a very minimal load on the generator, assuming no other loads. Your generator is basically running at idle and producing just over an amp.
As for where all the other amps are, they aren’t there. The generator will not produce more amps than are needed to power the load it sees. As the load increases the generator will produce more amps to support the increased load, up to the limit of the generator, which is limited by its circuit breakers. They are probably 30 amps on one leg and 30 on the other.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
