Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-07-2018, 09:22 PM   #1
Generator inverter issues
We just bought a 2013 Solera 24S and have it on it’s maiden voyage to Four Corners. Earlier today we turned on the generator to fire up the microwave and use an outlet. We couldn’t do either. The generator came on fine, however none of the outlets worked. I checked the GFCI in the bathroom and it wasn’t tripped. Is there a manual transfer switch or something we need to push to use the outlets while not plugged in? I thought the generator would have automatically transferred the 12v to 110. We still have a few more days site seeing and would love to use the outlets when not plugged into an RV plug. Thanks in advance!!
ChgoDave is offline   Reply With Quote
Old 04-07-2018, 09:24 PM   #2
Who Dares, Wins
doc73's Avatar
If it is an auto transfer maybe it has its own breaker on the unit or near the geni? DId the outlets work when hooked to shore power?
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 04-07-2018, 09:32 PM   #3
Yes they work when connected to shore. I’ll check on the breaker. Would the breaker be with the generator, or with the rest of my breakers?
Old 04-07-2018, 09:59 PM   #4
Who Dares, Wins
doc73's Avatar
It might have its own breaker on the geni or even a fuse of some sort on the transfer switch (assuming it is an automatic switch)
2015 Chevy HD D-Max
Old 04-07-2018, 10:04 PM   #5
Thanks! I’ll check it out when I pull over.
Old 04-08-2018, 04:06 AM   #6
First Rate Primate
Grape Ape's Avatar
Not sure if this is your situation, but my 2017 Prism doesn't have a transfer switch at all. To switch from shore power to the generator, I have to plug the permanently attached attached 30 amp cord into a 30 amp receptacle that is located inside the small power cord compartment. This receptacle is fed by the generator.
Grape Ape is online now   Reply With Quote
Old 04-08-2018, 06:25 AM   #7
Check the breakers on the generator itself. There may be two next two each other. If one needs to be reset, gen will run but not run outlets, etc. At least on my Onan 5K.
Rusty
lcv800 is offline   Reply With Quote
Old 04-08-2018, 06:33 AM   #8
One of two things.
The circuit breaker that is on the generator itself is tripped. Sometime they can be hard to find, look closely with a flashlight. Every generator has one. It will be inside the generator cabinet.
You may not have a auto transfer switch. If your power cord is permanently attached this may be the case, if so look in the compartment where the cord is you may see a outlet to plug the cord into, this is the generator output. If it has a detachable cord then you will have a ATS.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 04-08-2018, 09:22 AM   #9
has it ever worked on the generator? you never state what type of generator. do you have an ems protector in the input power supply cable? if you are using a portable inverter generator with the power cord plugged into it and have an ems it may be stopping power from getting into the coach due to sensing an open ground on the generator. if an internal generator check circuit breakers on the generator itself. and check the issue of whether you have an automatic transfer switch or if you need to plug shore power cord into an output receptacle from the generator.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 04-09-2018, 09:29 PM   #10
Old 04-09-2018, 09:30 PM   #11
Old 04-09-2018, 09:32 PM   #12
Old 04-09-2018, 09:33 PM   #13
So I found the black switch by the start button. It was turned off. I flipped it on and started the generator again. Still no power to the outlets. I check the fuses under the range and none are to the generator. Where would the generator fuse be located?
Old 04-10-2018, 12:53 AM   #14
I also checked and there is no outlet box connected to the generator by my shore power plug.
Old 04-10-2018, 05:11 AM   #15
Somewhere on that model there should be circuit breakers. Check to make sure they are both on.
Rusty
Old 04-10-2018, 05:34 AM   #16
In your picture in post #12 the “switch” you mention to the right of the start/stop switch is the generator circuit breaker.
If that is on and you canot locate a generator outlet in the bay where the piwer cord exits then you would have a auto transferr switch.
If you still have no generator power then either the generator has a issue or the ats has failed.
Old 04-10-2018, 06:28 AM   #17
sorry you are having this issue. it has to be frustrating. I agree with all steve-w said. that 'switch' is the output circuit breaker. you said it was off and you turned it on. try to reset it again by manually flipping it all the way off and on. this may hopefully reset it. try to trace to output power cables from the generator to see where they go. they will either go to a junction box with a receptacle in it or they will go to a transfer switch. need to confirm which it in order to determine the next actions. if a junction box with receptacle the shore power cord need to be plugged into it. if a transfer switch it will be necessary to start taking voltage measurements to see where power is present and where it is not. I reread and saw that you just bought this as a used unit. by any chance can the seller provide any input?
Old 04-10-2018, 08:41 PM   #18
I talked with the guy who sold it to me. He said to let it run for a few minutes. Sure enough, it worked!
Thanks for everyone’s help and suggestions!!!
Old 04-11-2018, 07:24 AM   #19
glad it was resolved. at least know you know a lot more about the generator. there is probably a time delay in the automatic transfer switch that has to elapse before it will transfer to generator power. this is done to protect a/c's from trying to restart when they still have pressure in them. same when it switches back to shore power from generator. plus in one post you said the output circuit breaker in the generator was in the off position. as long as it was off the generator would not provide any power. you flipped it and reset it
generator, inverter
