the red flashing light on the start switch is the error code. it will flash two sequences of numbers and then repeat the numbers several times. you need to count the flashes for the two numbers and record them. then look in the owners manual, or on-line, to see what the error code is saying. this will at least point you in a general direction.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
