Hello all,
The electrical receptacles do not work, well I do have one that works. The GFCI receptacle is the only one that has power, all the rest (4) do not have power.
Every YouTube video tells me to reset the GFCI and I have tried that but no luck.
Anyone have issues like this before?
Is there more than one circuit breaker for outlets? If you only have one, I would guess that the GFCI is the first on the string with the other outlets being fed from it. Lacking power at the other outlets would point me to a bad connection on the LOAD side of the GFCI outlet.
If there is another breaker in the panel for outlets, try resetting it.
2019 Palomino Solaire 147X
2013 Ford F150
