Originally Posted by Camperguy19
Outside plug an plug above sink plus GFCI does not work but all other plugs work. Changed GFCI an no power still an GFCI isnt tripped im giving up
I'm sure you snapped the appropriate (or all) circuit breaker off and on to be sure power is leaving the panel. Other wise, as Bama outlined, check each non-working outlet for faulty wiring on the back.
