10-11-2019, 02:42 PM
GFI
Gfi outlet is lite up and won't reset. Tried different GFI outlet and does the same thing. Breaker doesn't kick off just GFI no power to outlets. And help would be appreciated.
10-11-2019, 02:48 PM
Part-Time Campground Host
Is anything plugged into the other outlets?
Craig & Cath
Days camped since 2015(retirement): 1687
10-11-2019, 02:52 PM
X2
Or... one of the outlets downstream that this GFCI protects has water/moisture in it.
Also... I'm assuming things have worked correctly before today?
If this is a brand new rig, it could be wired incorrectly.
10-11-2019, 03:07 PM
As I look at the GFI plug cover a little closer is it burnt (melted) or is that just a reflection in the pic?
Craig & Cath
10-11-2019, 03:44 PM
Looks like a fried GFI outlet!
10-11-2019, 03:52 PM
X2. Could be a bad reflection, but it does look toasted. Additionally, is it wired correctly, i.e. LINE wires to LINE & LOAD wires to LOAD?
2016 Salem 27RKSS
10-11-2019, 03:54 PM
Year is a 2011. Everything work great up till now. It's not burnt just looks like it. Tried a different gfi outlet but it didn't work either.
10-11-2019, 04:03 PM
It is the "mouse" time of the year. Where are you located?
Loose connection maybe? Check the wires.
Craig & Cath
So... as mentioned... did you check the OTHER outlets that are daisy-chained to the GFCI?
10-11-2019, 04:21 PM
Have you had rain where you're at lately?? Check your outside outlet/s for any moisture.
2020 Chevy Silverado Crew Cab RST 4wd
2020 Grand Design Transcend 30RBS
Stolen and Totaled-2020 Coachmen Catalina Legacy 263RLS
WD4LTO
10-11-2019, 05:23 PM
Will check all outlets. Have been in heavy rain yesterday and today. Thanks to all
10-12-2019, 05:58 PM
Well outside outlet must have had water in it. Dried it out and low and behold GFI reset.[emoji106][emoji106]
10-12-2019, 06:53 PM
Yep, that can happen.
You need to see if it needs some sealer.
Glad you figured it out and thanks for posting. It will help others.
