Originally Posted by bisbur
Plugged a battery charger in the bay and the braker on the outlet at the door popped. I reset and only power at door. That is the only GFI that I can find
Some clarifications please; What popped? The GFCI at the the door or the breaker in the distribution panel or both?
Did you check the breaker in the distribution panel.
The Ground Fault Circuit Interrupter (GFCI) will not actually reset if the Circuit Breaker (breaker) in the distribution panel is tripped.
