Old 03-22-2020, 10:50 AM   #1
GFI/GFCI question
Forum,
I have read most articles pertaining to this subject, but I have run out of options when troubleshooting a finnicky GFI. Keeps "randomly" tripping.
Here are the facts:
1) AC panel is wire as sub-panel (no independent ground, only a neutral).
2) AC panel has ground conductor bar/bus connected to neutral bar/bus.
3) GFI/GFCI is first in the circuit.
4) All receptacles, lights, and breaker have been replaced.
Help, need suggestions.
D in Texas
djglover7 is offline   Reply With Quote
Old 03-22-2020, 10:53 AM   #2
SeaDog's Avatar
Have you tried replacing the GFI? Just asking
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-22-2020, 11:26 AM   #3
Are we talking about an RV or a stationary building?
I have a pole barn and had fluorescent ceiling lights on the same GFCI circuit as wall outlets. The GFCI would trip occasionally when turning on the lights. I rewired the fluorescent lights to a separate circuit and the GFCI trips stopped.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 03-22-2020, 11:27 AM   #4
GFI will be changed soon. It is in a very tight location and a PITA to work on.
Trailer is currently being renovated so it is not gone critical yet.
Old 03-22-2020, 11:29 AM   #5
Horse trailer with LQ.
Old 03-22-2020, 12:22 PM   #6
rsdata's Avatar
changing the GFI with a quality unit will probably solve your problem... they can and do get finnicky
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 03-22-2020, 12:43 PM   #7
Originally Posted by djglover7 View Post
Forum,
Here are the facts:
D in Texas
1) AC panel is wire as sub-panel (no independent ground, only a neutral). This is wiring for a main panel not a sub panel.
Sub panel must have neutral and ground separate. Neutral must be Isolated and any grounds bonded to metal
2) AC panel has ground conductor bar/bus connected to neutral bar/bus. This is wiring for a main panel
3) GFI/GFCI is first in the circuit. GFI is just a short abv for GFCI
What are you using when this random tripping happens??
Old 03-22-2020, 12:46 PM   #8
We ordered six from Best Buy , 4 were bad . We went to Ace and paid more for good ones .
wanderingbob is offline   Reply With Quote
Old 03-22-2020, 01:14 PM   #9
I used the wrong term. I thought I recalled someone referring to it as a "sub-panel" application. The construction is as I described. The feed is a standard 30A (3 conductor cable) from the shop.
I say random because it was happening before and after replacement of receptacles & lights (both types). On one occasion, I was standing nearby (stable electrical situation) and I heard the GFI trip.
Also, I was under the impression that I should NOT run AC to ground on the frame or aluminum body.
D
Old 03-22-2020, 01:27 PM   #10
good ones what
