Originally Posted by JSP
Sorry..I'm just frustrated. My juice pack has not worked since the day I brought it home. The furrion ( playschool) charge controller was so hot I thought it might catch on fire. Obviously something was fried. So I cut of the the wires and installed a wanderer controller ..two things happened. I had no current coming from the panel..and Forest River wouldn't do the warranty because I messed with the controller. I knew that would be the case but I figure this is such a simple system I will replace the panel and the controller and I'm done.
Well the new panel came.. and yes was still hooked to the battery. It is my understanding that you hook to the battery and then the panel? So if I start with the battery connected to the controller..if I try to connect the wires from the panel to the controller..the 10 amp fuse blows. Even if the panel is isn't connected.
Oh..and now I have the panel off the roof Im getting current..
Yes . Battery then panel, or cover the panel with a blanket and it won't matter. Done improperly, the controller could be damaged. I don't see how the 10 amp fuse would blow. 10 amp fuse is good for maybe 180 watt panel max.
