Originally Posted by NJKris
The OEM wiring is 8 gauge. Has no problem keeping my FLA's at 100%. Since the Li batt likes higher voltage during charging, I went with the 6 gauge for that battery bank, leaving the 8 gauge as is for now to the lead.
As for beer temp, I cringe when a bar pours a good beer into a frosted glass. I'm a bit of a beer snob, used to be a brewer. When beer is too cold, it hides the good flavors/aromas. But it also hides not so so good flavors of cheaper beer, so not all bad!
***Wire run length. I was surprised how much wire I needed to buy for the Li project. I only have a 20' trailer, with a ~17.5' box. By the time you run the cable down through wall from OEM controller, over side rail of frame, then up to where battery is, I'm estimating 25' run. I bought 30' lengths so I don't come up short on install. (Windy Nation).
Kris i went down my frig vent short cut but i have a 2608ws i removed the microwave & stove to get mine set up but this yr im adder to the set up
i use # 8 gage on my solar it keeps up but i put fuses wall mart sterieo fueses you can get the big fuses up to 80 amp's mounted them under the sink to the wall in the connection to bat and to the controled wair the solor comes in this way i just pull the batt fuse then i pull fuse to solar i have never covered the panels iv built quit a few systems for all my rv an house they probably say that becouse most people are not fermilier with the power or the diode in the box on the solar panel if you short them out you probably can damage the panels or the controler ...
2000 Dodge ram 3500 dully 5.9 cummins
2014 rock wood 2608ws UL full on customizing
Two side kicks Zoie & Cre
