Originally Posted by Hanesstetter
How do you set the battery type? And mine doesn't have bluetooth
It's done from the buttons on the front panel. It's not a great user interface, but here are the instructions for the non-Bluetooth charge controller:
https://gpelectric.com/files/gpelect..._GP_PWM_30.pdf
Check out Section 7.0 on page 11. Your controller, like mine, may have additional battery types, e.g., Lithium, but you cycle through those types using the procedure shown. The device shown has provisions for two separate battery types, but as long as there is a battery connected to Battery 1, you're fine. If you don't see Lithium as an option (that means you have an earlier production version of the PWM-30) and you wish to use Lithium batteries, the next best option is "AGM". Mine was in a 2020 ePro that we bought in 2019 and it had the Lithium option.
Have fun.
