Originally Posted by Wanda-R
Thank you for your reply Phil. I should have mentioned that my experience level is low. I drove the trailer home from Ohio to CT with an overnight stay and the batteries were fine, especially I assume since they were hooked up to the truck. I have it outside at a storage place and when I went back to it a week or so later, none of the 12V items worked at all. I hooked it up to the truck and they worked so I assumed a) the batteries were drained and b) the solar charging wasn't working. The next time I'm there, I'll take pictures of what the panel looks like but based on others I've seen on line, the controller panel it self has power but but doesn't indicate the charge in either battery
and the red and blue indicator lights aren't lit. Since it is brand new, I'm thinking it's an installation issue but I'm not getting much help from the dealer that is 700 miles away. Also you mentioned scrolling through screens which is also something that I can't do. Thanks again.
It would be good to see a screen shot. The setup is so simple that it is hard to envision it not being setup correctly.
Is this the 30 amp PWM controller with inputs for 2 separate batteries? Are your batteries setup independently or they wired together in parallel? Is this
a roof mounted system with the controller mounted on a wall? How many watts is the panel(s) rated for?
The fact that your controller is lighting up at all indicates that it is getting power from at least 1 battery.
Other than that, it is just a matter of putting the correct wire in the correct terminal. With the two independent battery system there are 6 wires and in the traditional one or two batteries wired in parallel there are only 4 wires or possibilities. This should be pretty easy to troubleshoot.
Regarding your batteries, I would recommend charging them and then disconnecting them via the battery shutoff switch, or, if you don't have a switch, disconnecting the negative cable so that the batteries don't discharge and damage the battery cells.
