Old 07-02-2024, 09:30 PM   #1
Chewman's Avatar
GoPower 100w not charging above .4 - .8
I went to clean my battery terminals (2 6 volt wired in series for 12v), covered the solar panels so no light could reach them, disconnected the positive terminal wires and when I disconnected the negative terminals it sparked. I have no idea why. I cleaned the terminals, reconnected everything and my GP-PWM-30-UL now only shows a charge from the 100 watt solar panel between .4 to .8. I reconnected the wires and made sure everything was tight. No change in the charging. I went to power boost mode and it didn't make a difference. The voltage on the battery is 12.6 so it should be getting more charging power to the battery. I did a soft reset on the control panel and no change.
I would appreciate any ideas on where to start my trouble shooting.
Thank you!
2020 Geo Pro G19FD
2018 Ford F150 2.7L V6 ECOBOOST
Chewman is offline   Reply With Quote
Old 07-02-2024, 11:27 PM   #2
Are you getting any reading directly from the panels with a multimeter (volts or amps)?
BTW, negatives should go on last, and come off first.
2023 Dynamax Force 34KD
-Demco Air Force One
2005 Toyota Tacoma 4x2 Crew Cab
-Remco 2pc Drive Shaft w/Disconnect
-Blue-Ox Avail Tow Bar and Baseplate
NewToTheForce is offline   Reply With Quote
Old 07-02-2024, 11:54 PM   #3
Hclarkx's Avatar
This is with good direct sun on the 100W panel, correct?
A PWM controller does not put out a steady DC current. It puts out pulses that get wider and closer together as the power increases. Inexpensive DC current meters or even expensive ones may not read the pulses all that well (they expect a smooth, constant DC current).
Are you sure you aren't seeing 4 to 8 amps? Is the ammeter you are using DC and is it auto ranging?
The voltage from the panel will be DC and smooth so should read well with any DC voltmeter. It should be up around 20 Volts in good sun.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 30' 8280WS Rockwood Ultra Lite
Solar, LiFePO4, 12V fridge, mini split
100% dry camping and boondocking.
https://hclarkx.slickpic.com/gallery/?viewer
Hclarkx is offline   Reply With Quote
Old 07-03-2024, 08:05 AM   #4
Clean up the battery connection .... That main positive sure looks bad
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-03-2024, 09:00 AM   #5
I think he did.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 07-03-2024, 09:03 AM   #6
Are you sure the batteries are low enough to accept a charge? It might be coincidence that you're seeing lower charging current after cleaning the connections. What are the batteries' voltage with no solar input?
2023 r-pod RP-192 with Beast Mode suspension
600W rooftop solar, 300Ah LiFePO4 battery bank, 2000W inverter.
Uses an electric coffee maker when boondocking.
"Never underestimate the power of human stupidity."
-Lazarus Long
jlankford is offline   Reply With Quote
Old 07-03-2024, 10:09 AM   #7
boy I missed that one... 3rd word
Jlankford answer is a good one
discharge the battery down somewhat and test again.
or simply turn on some 12v loads (lights and furnace) the panel should show a bit more current
Tarpon Springs FL
2022 Salem 24RLXL
Old 07-03-2024, 11:13 AM   #8
Trailer Park Supervisor
NJKris's Avatar
The current will continue to drop as battery approaches full charge, that's the job of the controller. Try pressing and holding BOOST button for 3 seconds to put it in BOOST mode, wonder if that will make a difference. It may just increase voltage for a short while, no necessarily current if it's that full.
edit, just read your original post again, I see you tried that and saw it didn't make a difference.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 07-09-2024, 11:39 PM   #9
Chewman's Avatar
Thank you all for your imput!
I watched a video that showed even if a small portion of the solar panel is blocked it can dramatically reduce the amount of charge to the battery. I made sure the entire panel did not have any shade and I received 7.2
I also watched a video that showed checking a solar panel on the roof and it sparked and started a fire. It didn't show what caused it.
To check the solar output is it really as simple as disconnecting the connectors on the roof and connecting a meter to it? I really don't want to get shocked when I'm on the roof of the trailer!
Thanks again to all for the help and suggestions!!
2020 Geo Pro G19FD
Old 07-10-2024, 06:23 AM   #10
You could first try to make the measurement at the solar controller terminals. Remove two screws and pull the GoPower SCC out of its mounting hole to access the terminals on the back.
-Lazarus Long
Old 07-10-2024, 06:31 AM   #11
Do they make a low cost clamp on ammeter for measuring less than 30 amps? Would be easier.
My clamp on is basically for starter circuits.
2022 Rockwood 2511S
Old 07-10-2024, 07:08 AM   #12
I have one from Klein Tools, CL380 but not available on Amazon now. I do see a number in the $40 range. Be sure to read the fine print and get one that does DC amps. Many are AC only.
Another option would be to install a shunt on the battery. That would give you current readings but the bonus would be that it would track the charge/discharge currents and give you a battery level reading at a glance.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 07-10-2024, 08:07 AM   #13
Amazon PRIME day is coming up
maybe you can get a better price next week?
https://www.amazon.com/s?k=dc+curren...l_12to6y1tax_e
a DC clamp meter is a bonus tool to troubleshooting 12v especially if you start getting multiple batteries and solar etc
saw this Klien 390
https://www.amazon.com/Klein-Tools-C...0616570&sr=8-6
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-04-2024, 07:43 PM   #14
Chewman: Did you get this resolved? The reason I ask is on my 2024 FR3 34DS the solar is not charging the batteries. When look at the solar controller display the solar panel voltage reads .6 volts. I have checked all the connections, even the solar panel plugs on the roof. I have not checked the output of the solar panels on the roof with a meter. I did check at the controller with a meter and the reading matched the controller.
I am not sure if there is a fuse inline between the panels and the controller. I will check the solar panel output from the roof soon. Any one else have any ideas?
2024 FR3 34DS
2012 Jeep Wrangler Sport toad
SuperJoe303 is offline   Reply With Quote
Old 08-04-2024, 07:53 PM   #15
rsdata's Avatar
With ONE 100 watt solar panel and a 12 volt battery connection there is absolutely ZERO chance of you getting shocked with anything you now have...
2014 Shamrock 183
Old 08-04-2024, 10:04 PM   #16
Rhumblefish's Avatar
Now, if you somehow manage to get your tongue across both terminals on the 12v… That might be a little different
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is online now   Reply With Quote
Old 08-05-2024, 08:50 AM   #17
Chewman's last post described the system was working fine. He didn't fix anything, he just made sure the panel was in full sun for his measurement and he got 7.2 amps.
If your SCC only shows 0.6V panel voltage you have a connection problem somewhere you haven't located. FYI, that is basically an open-circuit voltage - my SCC displays 0.6V for my panel voltage right now, and the wires aren't even connected.
My r-pod factory installation did not have a fuse between the PV and SCC anywhere that I could locate. Don't know if yours might have a fuse. You should check in the wiring space behind where the SCC is mounted. It's possible you have an inline fuse up at the roof gland, so when you're up there measuring panel output look carefully for that - it could be mistaken for part of the MC4 connector assembly.
-Lazarus Long
charging, power
