Old 05-09-2011, 03:31 PM   #1
Boyd's Avatar
Green fuzz on positive battery terminal
I just checked my sealed batteries inside the motorhome (three 140Ah in Parallel) and noticed green fuzz around one positive terminal. Question: Does this mean that the battery has a crack in it? If so, is there a way to check for leaks? Again, this is inside the rig, under a seat and has me VERY concerned. Thanks for any help.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 05-09-2011, 03:36 PM   #2
wmtire's Avatar
When you say "green fuzz", it's not a battery terminal protector felt washer like the ones pictured below is it?
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
Old 05-09-2011, 03:47 PM   #3
Boyd's Avatar
Discription of green fuzz
I don't have the felt pads on my terminals. The "Green Fuzz" is more like bits of small flakey bits of powder stacked around, and on top of, the terminal.
Old 05-09-2011, 03:55 PM   #4
wmtire's Avatar
More like this, then?
Old 05-09-2011, 04:17 PM   #5
Boyd's Avatar
Pictures of fuzz
Here is my little pile of fuzz.Click image for larger version
Old 05-09-2011, 04:24 PM   #6
Surveyor Sam's Avatar
That's common corrosion. Don't get it on you, your hands, your eyes, or your clothes. Remove the wires, clean them, and clean up the corrosion. It's typical maintenance on batteries.
edit: you can add those green felt washers shown above. They help reduce the corrosion.
[*]2010 Forest River Surveyor SV-230[*]26 nights in '11, 32 nights in '12, 30 nights in '13[*]30 nights in '13, 38 nights in '14, 32 nights in '15
Surveyor Sam is offline   Reply With Quote
Old 05-09-2011, 04:31 PM   #7
Boyd's Avatar
Feeling better already. Do you you happen to know what causes the corrosion; Loose connection? Cracked battery? Thanks for your help.
Old 05-09-2011, 05:08 PM   #8
cheese53073's Avatar
that is normal oxidation caused by the acid in the battery no leaks or cracks it just happens. Use baking soda and water to clean it as it nutralizes the acid
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 05-09-2011, 05:12 PM   #9
Boyd's Avatar
Phew! Thanks folks, it's cocktail hour, and today I'll have something legitimate to celebrate.
Old 05-09-2011, 05:17 PM   #10
Pour one for me also please
Rockwood 8293RKSS
Old 05-09-2011, 06:37 PM   #11
You can cover the terminals with protective gel available at most auto parts stores. Vaseline is just as effective.
Ryan
2003 Georgetown 303
w/V10 Ford Chassis
Rboileau is offline   Reply With Quote
Old 05-09-2011, 06:43 PM   #12
I've used vasoline and it does work well. Baking soda will neutralize the acid, but make positive sure it doesn't get into the battery. It will neutralize some of the acid in the battery as well. I think the fuzz is caused by galvanic action. Its where two dissimilar metals come in contact. It'll happen in non-lead batteries too.
Old 05-09-2011, 06:48 PM   #13
Herk7769's Avatar
You hit it square Sam.
HAM CALLSIGN - KC3FFW
battery
