Old 10-09-2020, 09:12 AM   #1
Smile Guide to RV Electrical for IDIOTS??
I recently bought my first RV (2017 Sunseeker MBS 2400 DW) and maybe I have a 5th graders understanding of electrical systems (apologies to any 5th graders who might be offended ....but I'm trying to learn quickly. Does anyone know of information available for:
1) A BASIC guide as to how the electrical system on my RV is set up?
For example, to answer simple questions like, does the truck alternator charge the RV house batteries? And how are the two connected?
2) A good primer on how RV electrical systems work?
Thanks in advance.
Eric Heffel is offline   Reply With Quote
Old 10-09-2020, 09:19 AM   #2
Book Recomandation
Here is what I purchased to help me understand RV electrical system, helped me but YMMV.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
FYI; I got the book as I am looking to install solar, but still good basic information on 12 volt and 110 volt systems used in campers.
2020 Rockwood 2612WS
2019 Ram 2500 Cummins
Theb2b is offline   Reply With Quote
Old 10-09-2020, 09:49 AM   #3
NXR
NXR's Avatar
This one might also help but I've never read it. The author has columns in RV publications and gave talks at gatherings when there were gatherings.
https://www.amazon.com/No-Shock-Zone.../dp/0990527913
Unfortunately, you'll learn that your "how are..." question will always have an answer of "It depends" because each manufacturer does things their own way and it can vary even from model to model and from year to year.
"Usually" but on some you will need to assure that the battery master switch inside the RV is turned on for the house batteries to charge from the alternator or from the shore power cord plugged into the campground pedestal.
"Usually" it's just a wire from the truck's electrical system to the towing connector on the truck, through the electrical cable between the truck and the RV, and into the RV. Somewhere in the truck and somewhere in the RV there will be a fuse or circuit breaker. Usually. <sigh>
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 10-09-2020, 10:01 AM   #4
Just Tryin' to Help
cboss's Avatar
Give these a read "The 12 volt Side Of Life" Part 1 & 2.
The 12volt Side of Life (Part 1)
The 12volt Side of Life Part 2
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 870
cboss is offline   Reply With Quote
Old 10-09-2020, 10:08 AM   #5
Ray
Many decades ago manufacturers of many household appliances were required to provide at least basic schematics for their circuitry.
We see these for our refrigerators and A/C units installed in our RV's.
UNFORTUNATELY no schematics seem to exist for any of the wiring installed in them. Wouldn't it be nice to at least know if a Circuit Breaker of Fuse was installed in the line feeding either the entire RV's 12 Volt system? How about letting us know there is a separate fuse for the radio or range hood fan inline somewhere (often hidden so you have to remove the device to find it).
The reason the old appliance manufacturers include the diagrams is because it became a government mandate.
Sadly, that's what it will take to get RV manufacturers to do likewise. Even car manufacturers had to release their wiring diagrams to the public.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-09-2020, 01:38 PM   #6
There is no rime nor reason to rv wiring !! good luck, you'll need it !!
azwiz is offline   Reply With Quote
Old 10-09-2020, 01:42 PM   #7
Electrical
We own a 2016 Sunseeker 2400W. I've never seen the DW. I'll just give you a few things we've learned. Your batteries in the chassis will go dead if you don't either keep it plugged in, have solar, or use a battery tender. We keep ours plugged in to a outside outlet in our home. Works well. Turning off the main switch located near the door will not keep your batteries from dying as there are parasytic draws( smoke and carbon monoxide detectors) etc. We replaced our batteries at 3 years. First the coach then the chassis went out. Our fault because we didn't know. Always either run the generator or be plugged into 30 amp to use the slide. All this is just basic but maybe it will help. Enjoy your rig we love ours.
Desertsquid is offline   Reply With Quote
Old 10-09-2020, 02:36 PM   #8
bikendan's Avatar
The best primer on RV electrical systems.
Old 10-09-2020, 02:54 PM   #9
Just as confused as you
Scrapper's Avatar
Thanks in advance.
Besides "The 12 volt Side Of Life" Part 1 & 2 given elsewhere in this thread you may want to check out this thread https://www.forestriverforums.com/fo...ts-157524.html by wmtire.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 10-09-2020, 02:58 PM   #10
221fisher's Avatar
electrical
X2 for No Shock Zone by Mike Sokol
Johnny & Ginger
2019 Rockwood Mini Lite 2109S
2017 F-150 3.5 EB, SC, 4x4, Max Tow,
Every choice is an opportunity to say yes to God.
221fisher is offline   Reply With Quote
Old 10-09-2020, 03:19 PM   #11
camaraderie's Avatar
My suggestion in addition to the basic reading and education on common RV electrical issues you can ALWAYS get here,,, is to buy a $50 ac/dc clamp meter and use the instructions and you tube videos to learn the basics of measuring voltage, current and continuity which will let you logically track down and figure out issue like does my alterntor charge my house batteries? Is my connection from the alternator supplying current? How much current does my alternator supply and how discharged are my batteries?.... As well as...What voltage is my campground electric and is my converter charging my batteries and does my cable TV wire have a break in it? etc.
Important that it be able to measure AC AND DC current. Here's an example:
Mastech MS2109A True RMS Digital AC DC Clamp Meter 600A Temp NCV RC Test Tester
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 10-09-2020, 05:14 PM   #12
a couple suggestions
Two things:
1. the truck may or may not charge your RV battery. A) you need to make sure the battery master switch is "on", if it is, your 12v lights and fans in the RV will operate. B) The charge circuit to the correct pin of the 7 pin factory connector is installed on a relay. Often, that relay is not installed in the truck and you have to buy one when you buy your RV. About 5 to 10 bucks, your RV or Tow vehicle dealer can help you find it.
2. Might be a good idea to simply read your Converter / Charger manual. Here's one:
https://progressivedyn.com/pdfs/109205n%20english.pdf
Read a few from your mfg or others, might pick up a few things.
Steve W indy is offline   Reply With Quote
Old 10-09-2020, 05:38 PM   #13
Scrapper's Avatar
Originally Posted by Steve W indy View Post
Two things:
OP has a motorhome, not a truck for towing a 5er or tt.
Richard & Jill
Camping since 1989
Old 10-09-2020, 06:48 PM   #14
Thanks in advance.
Try going to phreds poop sheets he covers just about everything pertaining to tv's vert interesting site. I know a weird name but well worth the effort.
slgjeg435 is offline   Reply With Quote
Old 10-09-2020, 06:55 PM   #15
...far N Georgia!
formerFR's Avatar
some of us want to learn and totally understand everything before we ever turn the key...
some of just learn when something goes 'wrong'...
some never learn : )
The Turners...
'14 Thor Palazzo 33.3 compact diesel 100k+miles since '14... US, Alaska, Canada...
AND a '14 Gulfstream Amerlite
AND a '07 ForestRIver Rockwood : )
formerFR is offline   Reply With Quote
Old 10-09-2020, 07:57 PM   #16
I found RV Electric has some information.
Grumpy7159 is offline   Reply With Quote
Old 10-18-2020, 05:14 PM   #17
Many thanks
Many thanks to everyone who responded because you have been extremely helpful. I the last 2 weeks, I've gone from 5th grade electronics to maybe 8th grade.....but it's progress.
I bought the book, Managing 12 Volts. I got myself a good clamp meter, and I've been digesting the 12 Volt Side of Life. And I'm doing some tinkering.
I've got a long way to go, but I think I've at least figured out how not to get stranded with dead batteries again (which has happened twice, and I only got out of it using some portable solar panels that came with the rig....which I also don't understand very well.....yet).
Old 10-19-2020, 08:59 PM   #18
Darryl Honda's Avatar
Excellent answers from Titanmike and bikendan, those guys know their ****, all I can add is if you buy a volt meter or an amp meter or both, especially digital as opposed to analog, learn to use it and learn to understand what it is telling you. I've been a commercial/industrial electric guy for a long time and have seen electricians read a meter and see the OL come up and tell me .... oh... it's an overload....lol All I can say is a meter will be a life saver if you know how to read it.
25 FBS 2017 Puma
Darryl Honda is offline   Reply With Quote
Old 10-20-2020, 01:35 PM   #19
Jump on Utube. Look for RV electrical as there are a ton of videos covering all aspects of RV electrical systems, some new some older, but I have found them helpful.
kjlars is offline   Reply With Quote
electric, electrical
