Old 06-15-2024, 05:36 AM   #1
Rmrock824's Avatar
Half of RV has no power
Greetings I'm at my very first campground and half of my Cardinal Red 31rl has no power to the outlets and the main A/C has no power and last but not least the control panel for the slide outs is blinking where I would select the particular slide out to retract. Thus it won't let me retract any of the slides
Any advice or suggestions would be greatly appreciated
First Timer,Old Timer
Richard R
Rmrock824 is offline   Reply With Quote
Old 06-15-2024, 06:17 AM   #2
Oaklevel's Avatar
Assuming that the trailer is a 50A power supply. It sounds like one leg of the main 50A power is out. If you on a campground pedestal check your breakers. Flip them completely on the pole and the power box in the trailer.
How are you hooked up to the pedestal? To a 50A outlet or a 30A outlet with an adapter?
Can't help with the control panel as we do not have one.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-15-2024, 06:21 AM   #3
Rmrock824's Avatar
I'm in a campground connected to a 50 amp all the breakers at the connection point are on. Green lights on the surge protector also. The A/C in the bedroom works but not the main A/C and microwave.
Old 06-15-2024, 06:22 AM   #4
Rmrock824's Avatar
None of the 120v plugs have power
Old 06-15-2024, 06:45 AM   #5
Oaklevel's Avatar
Have you checked your main breakers? in the trailer?
A 50A trailer has two legs one AC is on one side the second AC is on the other side.
1966 Mustang GT
1986 Mustang SVO
Old 06-15-2024, 06:47 AM   #6
Rmrock824's Avatar
Yes I have but the 50amp breaker is only one
Old 06-15-2024, 07:02 AM   #7
Flybob's Avatar
Turn 50A breaker in trailer off and back on. Also check connection between main power cord and rv.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-15-2024, 07:04 AM   #8
Rmrock824's Avatar
Done but no change. I'm thinking the 50amp breaker on the campsite post is defective. I'm going to hook up to the 30amp and see what happens
Old 06-15-2024, 07:25 AM   #9
Do you have a meter to check the voltage at the campsite post?
Baker9713 is offline   Reply With Quote
Old 06-15-2024, 09:37 AM   #10
Most likely. I had this exact problem once. Had to have the CG change the breaker on the post.
Iwritecode is online now   Reply With Quote
Old 06-15-2024, 10:11 AM   #11
Rmrock824's Avatar
After all I found changing to 30amp fixed the problem. Thanks to all for the suggestions and support. Great Forum
Old 06-15-2024, 10:42 AM   #12
Mr. Dan's Avatar
Except for the fact that you now have a total of 30 amps instead of 100 amps.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 41; Booked for 2024 = 55
Old 06-15-2024, 10:51 AM   #13
Rmrock824's Avatar
Called the park management and they are on their way with a new breaker
Old 06-15-2024, 12:54 PM   #14
Good job!
Good job!
Larry
Larry-NC is offline   Reply With Quote
Old 06-15-2024, 12:59 PM   #15
Now that you've found the problem....
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
no power, power
