Originally Posted by spock123
My Cedar Creek is 50amp and I keep it plugged in all the time at home, however only 30amp is hooked to the plug. Only 30amp feeds the 50amp receptacle. I do not have a dog bone, everything is 50amp. My electrician hooked it up for me, everything works in camper.
The way you are describing your setup, your outlet is most likely wired as a 30 amp 120/240 volt with a double pole breaker.
This is not the same as a 30 amp outlet wired 120 volt with a single pole breaker as RV's use.
Your setup is capable of a total of 60 amps, as opposed to 100 amps with a normal 50 amp 120/240 volt split phase outlet.
