Old 09-22-2020, 08:52 PM   #1
Ari_Darkflower's Avatar
Hi there, newbie here. Is this for the solar setup?
In my 2016 flagstaff micro lite 23fbks, under the bench seat and table was all this equipment. Anyone know if it is for the solar setup? It was in the way of the table laying down and turning into a bed. The red 700 watt amp is connected to one of the batteries under the seat. I also realized I have the two batteries outside on the tongue and now these 2 batteries inside, is 4 batteries normal?
I apologize for my complete lack of knowledge, I am still learning, but when I got this trailer no one could tell me how anything worked, because it had belonged to my dad and he is no longer a member of this Earth. I know he used the trailer to go to Colorado and lived there in it for 6 months to get away from the Florida heat. I thought maybe all that electrical equipment was something he added? There is a red 700 watt amp, a blue speed/charge and the black box is a dish network Wally.
ID:	239752   Click image for larger version
Ari_Darkflower is offline   Reply With Quote
Old 09-22-2020, 08:58 PM   #2
With the 120 volt Multi strip in there, I'm thinking the 700 Watt is a Inverter. It Converts 12V DC to 120 Volt AC using just the batteries. That way if you don't have Shore Power.....plugged into a 120V outside source, you can use the batteries to to run 120 volt appliances.
Look on the roof for Solar Panels ??
TheWolfPaq82 is offline   Reply With Quote
Old 09-22-2020, 10:00 PM   #3
Thank you for the info, I understand better now. I did find a solar panel he had stored behind the couch. It folds in half and is about card table size when unfolded.
Old 09-23-2020, 03:18 AM   #4
bikendan's Avatar
Are those FLA wet batteries and are they inside the trailer?
Equalizer WDH
Old 09-23-2020, 07:55 AM   #5
Sure appear to be.........
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L
01tundra is online now   Reply With Quote
Old 09-23-2020, 11:54 AM   #6
I don't know what kind they are, but yes, they are under one of the bench seats inside. What does that mean if they are FLA wet batteries inside?
Old 09-23-2020, 12:02 PM   #7
I just read about FLA wet batteries. I need to be sure to charge them outside?
Old 09-23-2020, 12:04 PM   #8
KEEP them outside.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 09-23-2020, 12:09 PM   #9
Originally Posted by chriscowles View Post
KEEP them outside.
Ok, there are already 2 batteries on the tongue. I saw there are little tows you can put on the back of campers. Would that work for the batteries that are inside? And I need to keep them outside cuz of noxious gasses that come off them? The gasses are made only when they are in use correct?
Old 09-23-2020, 12:27 PM   #10
Or should I replace them with a different kind of battery? I am pretty certain they are for the solar power setup.
Old 09-23-2020, 04:51 PM   #11
Is it possible to contact the original sell and get a full explanation of what you are looking at? If so, I'd start there and get a detailed description of what has been done. I'd encourage a non-judgmental, non-confrontational learning session. You need all the info, and if you critique, your education may be cut short.
FLA (flooded cell lead acid) batteries must be vented to operate safely, and they must be kept away from ignition sources (e.g. sparks). When working, a conventional lead-acid battery emits gasses that can explode. https://www.latimes.com/archives/la-...902-story.html
Things you need to know from the original owner:
1. Are there solar panels permanently mounted on the roof? Look for yourself.
2. If so, where is the wire routed from the panels to the charge controller and how? What gauge is the wire? It should be at least #10. How are the roof-top panels wired: all parallel; series/parallel; series? (there are advantages and disadvantages to each option.)
3. If so, where is the charge controller?
4. How is that charge controller wired to the battery bank? What gauge wire? Where does it connect (outside on the tongue or inside in Rube Goldberg heaven under the bench)?
5. How are the two battery banks connected to each other? What gauge wire is used? Looking at your floor plan, these batteries are FAR apart!! That calls for some very serious wire to connect them together to behave as one big battery.
6. Are these 6 volt or 12 volt batteries? (I can't see them clearly enough to count the cells).
7. Since many large RVs have batteries "inside" a vented space, is it possible your under-seat compartment was vented by the original owner? If so, how and where? (A forum discussion on the subject: https://www.cruisersforum.com/forums...nt-174176.html As you might imagine, a battery explosion at sea that may cause a fire is a very serious matter.)
8. Assuming your folding (suitcase) solar panel is supplemental to roof-mounted panels, does it have its own charge controller? Does it plug into the "Zamp" (or other brand of) quick connect on the tongue or near a cargo bay? These connections are notorious for their lack of charge controller, so you must supply one with the suitcase panel or risk damaging your battery bank by overcharging. And don't mistake a diode panel on the back of the solar panel for a charge controller. A diode panel will be "upstream" of the charge controller...first the solar panel, then the diode panel, then the charge controller.
9. If the suitcase is all there is, you need to know that, because a 100 watt suitcase panel array is hopelessly inadequate to charge 4 (or even 2) big batteries. You may need to add considerably more if you don't want to run out of battery before your boondocking trip ends (or you don't want to listen to the delightful drone of your generator for endless hours).
10. Ask for a rationale for this installation. What was the original owner envisioning when s/he made these choices? If the plan was to go out into the field with a massive battery bank and run it down...with a tiny bit of help from the inadequate suitcase solar panel...that's not a bad plan, but you need to know that plan to understand the choices made. If the original owner had the misguided notion that a 100 watt suitcase solar array could defy the laws of physics and generate 150 amp hours of charge per day, well, that happens.
Having 4 batteries on your relatively modest rig doesn't make a lot of sense...especially 4 x 12 volt batteries. Big rigs, such as fifth wheels, may run 4 x 6 volt golf cart batteries in series/parallel to deliver 12 volts, but at 65 pounds or so per battery, only one of those batteries is factored into the 809 pounds of cargo (including fresh water) you can carry. 3 more batteries eat up about 195 pounds of cargo capacity. And bear in mind that a full freshwater tank (36 gallons) will consume 300 pounds of those 800 pounds all by itself. Batteries and water together = 500 of the 800 pounds. You can't possibly get by with only 300 pounds of cargo if you plan to boondock!
What WOULD work well is a pair of 6 volt golf cart batteries on the tongue wired in series to make 12 volts. These two batteries can supply about 115 amp hours of USABLE power on a full charge, and one extra battery (and extra weight of the first battery) will account for about 75 pounds of cargo capacity.
Add in a 400 watt roof-mounted solar array...here's an example: https://smile.amazon.com/WindyNation...s%2C199&sr=8-4
You most definitely can do better with an MPPT (maximum power point tracking) charge controller instead of PWM (pulse width modulation) controller for another $100 or so. I'm using a PWM controller and doing great. Shipping weight of this kit is 71 pounds...installed weight about 60 pounds once you dump the packaging.
Lastly, the 700 watt inverter is fine as far as it goes, but what you really need is a 2KW inverter generator to make 120 volt power. Not much, whether microwave or espresso machine, can run on 700 watts. And if you want to run your micro with an inverter, it's going to eat 100 amps of 12 volt power while running. You'd need a 2000 watt inverter to power the micro, and you'd need to connect it to the battery bank with welding cable. Run the micro for 15 minutes, and you'll use 1/4 of your battery bank!! A generator is the right choice for large 120 volt loads. Let the batteries do the 12 volt work and you'll be very happy.
There a many options for generators. This is a good 2 KW model: https://www.harborfreight.com/mercha...tor-62523.html
If you envision yourself running the AC now and again, this one will do it with ease: https://www.harborfreight.com/mercha...tor-63584.html (In most cases, a 2000 watt generator can't quite muster the power to run air conditioning.)
And, when it's all said and done, when it's raining like hell and you need to stay inside with a batch of kids, a generator will save your bacon. You can watch TV, charge devices, run toys and appliances, all the lights, stereo and more while you're hunkered down, and the genny will keep your battery bank topped off.
In conclusion, why the big diatribe? I'm not sure what you bought. A bit of a pig in a poke. I used the words Rube Goldberg...and it sure looks like it. But you have the parts and pieces of the start on a pretty good system. Ask yourself what YOU need it to do and adapt accordingly. If you're a park denizen, addicted to hookups like shore power and city water, all of this is pointless. But if you're going to boondock - really go "camping" as some of us would claim - you need to understand this stuff and start coming to grips with the fact that even god's own battery bank is a pathetic way to store power. A 5 gallon (actually 4.5) tank of propane holds the energy equivalent of 10,056 amp hours of energy. My puny 115 amp hour battery bank (a damned good one) holds 1/100th of that amount. Understanding energy, how to make it and how to consume it, is crucial to an enjoyable boondocking trip. Methinks the guy who put that "stuff" together didn't quite have a grasp on the basics. Close, but no cigar.
My rig is below. I boondock exclusively...once this summer for 10 days straight. I'm in sunny Colorado. With my new system, I am now a profligate power user...stereo on day and night, lots of lights, and so on. We even run an electric blanket for about 20 minutes through a 500 watt inverter (after quiet hours) to take the chill off the bed before we climb in. I use the genny ONLY to make lattes (yes, we are spoiled) about 15 minutes in the morning and 15 minutes in the early evening. Meanwhile, my charge controller tells my batteries are always topped off by Noon!! At 9 AM my charge controller reports about 19 amps of charge, and by Noon, it's down to a trickle, because the batteries are already full.
Specs:
400 watts on the roof;
2 x 6 volt golf cart batteries;
A 2000 watt genny.
Name:	Solar on Jayco Close.jpg
ID:	239820   Click image for larger version
Name:	Jayco Renology Solar Kit.jpg
ID:	239821   Click image for larger version
Name:	Neoprene Package.jpg
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Wellington
jimmoore13 is online now   Reply With Quote
Old 09-23-2020, 05:04 PM   #12
jimmoore13
You missed this portion of the original post it had belonged to my dad and he is no longer a member of this Earth.
We're sorry for your loss and hope you get this figured out soon.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-23-2020, 07:58 PM   #13
Thank you and thanks everyone for sharing knowledge. After reading what everyone shared and confirming it is for the solar setup, I think the best thing to do is take it all out and redo it. That way I know what's going on and it's safe.
Thanks again everyone, you all are very nice people!
Old 09-24-2020, 07:39 AM   #14
Looks like you have the beginnings of a decent system. Research this forum as there are many posts about setting up solar in your trailer. You can also search the model numbers and brands of the components he left for you and see how they would fit in with an overall system. I use Amazon a lot for that purpose and you can read reviews about whether the component is something you actually want to use. Sounds like you have a solar "suitcase" setup for your panels. There are a number of very good portable setups out there so do a little investigation. He may have left you a gold mine.
One last thing, if those batteries are AGM's or Flooded cell batteries, get them out from under that seat. The vent gasses that are very flammable and corrosive.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is online now   Reply With Quote
Old 09-24-2020, 08:23 AM   #15
TowPro's Avatar
you can put AGM batteries in side, but not lead acid.
Those look like Walmart EverStart Lead Acid Marine and RV deep cycle group 29DC
I don't think they are AGM. Specs say "maintenance free under normal use" but that could be these battery caps made to stop the vapor lose and turn it back into water. Most of the AGM I have seen appear to not have any way to open battery.
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
Old 09-24-2020, 09:00 AM   #16
You sure about that?
Page 2, states that they have a relief valve in case of overcharging and off-gassing, so it's recommended to run a vent out at the very least. Even though this is not a "sealed box" situation, in case something went wrong with charging I wouldn't personally want them relieving inside my trailer.
http://www.dekabatteries.com/assets/base/0139.pdf
https://rvnerds.com/2017/11/01/elect...ging%20process.
Old 09-24-2020, 11:06 AM   #17
TowPro's Avatar
Probably true, and I would not do it, but I am saying what I read on internet and that means its got to be true.
Oh, we have 1000's of lbs of AGM batteries running 3 phase circuits in UPS racks all over the data center floors, next to electronic switching power feeds for fail over.
newbie, solar
