Maybe... the light in the switch could have broken. You can check the connections on the back of the switch with a multi-meter to make sure you have power coming and going. Could be a bad fuse too.
You don't indicate what unit you have. Some tank heaters do not run on 12V. Also possible that you do not actually have a heater option, but the switch is in the panel for that model.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
You don't indicate what unit you have. Are you connected to shore power. Tank heaters do not run on 12V. Also possible that you do not actually have a heater option, but the switch is in the panel for that model.
Tank heaters do run on 12 volts in most units......
